Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Our Freezer is leaking into the freezer and down to the refrigerator. We cleaned the coils, should this be enough, or is this some other problem? Please let me know what I can do...
  • Whirlpool Master
  • 1,606 Answers
Remove the food and the ice maker ( if equiped ) , and remove the screws holding the back freezer panel . Remove the panel . Using a hair dryer , start in the middle below the coils , defrosting , until you see the drain hole . Use hot water to help clear this hole . Once the water starts to flow , use a small hose , inserted into the drain hole and blow thru it , to remove any debris built up in the unseen drain line .
Posted on Sep 26, 2009
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
The Refrigerator's Freezer is not working but the fridge is, what is wrong?
You probably have one compressor that cools the freezer section and the refrigerator section. Usually the freezer gets cooled directly with the cooling coils. A fan blows cool air to the refrigerator section. The air flow to the refrigerator may be modulated with some time of "air door". What you have written says to me, is that the fans and air doors are working but there is enough cold for the refrigerator but not enough for the freezer.
Here is what I would do:
  1. Put a thermometer in the refrigerator and in the freezer.
  2. Be sure the coils underneath or behind the refrigerator are clean. If they are very dirty, clean them.
  3. Keep the doors shut for at least 12 hours and then read the thermometers and write down the temperatures.
  4. Freezer temperature
    1. If the freezer has started freezing again, you fixed it by cleaning the coils
    2. .If the freezer temperature is between 0 deg F and 32 deg F, consider putting the food in a cooler and packing in some dry ice to try and save it.
    3. If the freezer is warmer than 32 deg f, throw away the food.
    4. Doctors and hospitals are pretty expensive. I would throw away the food no matter what the thermometer read.
  5. Look inside the freezer at the cooling coils. See if they are ice coated or not.
    1. If the freezer is above 0 deg F, and the coils are ice covered, the defrost control is not working. Unplug the refrigerator for 12 hours and let the ice melt. (Keep the doors shut.) Then, plug in the refrigerator for 12 hours and check the temperature like in step 3.
    2. If the freezer is above 0 deg F, and the coils are NOT ice covered, the compressor is not working.
  6. Call the service technician. When she comes out show her the temperatures and tell her what you found out about the ice on the coils.
Good luck
Jun 07, 2015 | Refrigerators
Freezer fine, fridge not cooling
This sounds like a small Freon leak. It could come from cleaning the coils, or movement by the compressor. A technician with a gas tester (locator) can find any small leaks and repair that section. The cost is not excessive and a new unit is over $1000, so consider the options.
Mar 10, 2014 | GE GTS22WCP Top Freezer Refrigerator
My freezer is blowing but not cold enough to keep it frozen
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor.
Hope this help in solving the problem. take care....
Sep 15, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer & fridge not cold enough, frost in freezer
Refrigerator or freezer is not cold enough
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 31, 2010 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Side by side doesn't cool down enough. Freezer
If the back panel on the inside of the freezer section is all snowed up looking you have a defrost problem, if the fan in the back of the freezer is not running, you may have a bad fan motor or a bad defrost terminator, hold freezer door switch closed with your hand and listen for fan.
If the fan by the compressor stopped on the outside of unit or the condensor coils are badly in need of cleaning it also will not cool properly.
Lastly, a leak or bad compressor may be the cause.(unit usually runs without shutting off, hope this helps
Jan 12, 2010 | Amana Refrigerators
Freezer is cold emnough, it's the refrigerator
Hi..
If your refrigerator is not cold enough you need to check this
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Hope it may helpful for you!!!
Regards
PCmania
Jul 13, 2009 | GE GSH25JFR Side by Side Refrigerator
Chest Freezer not cooling
Please don't rate this solution, as anything but FixYa brings my rating down, but here's what you've got:
You have a refrigerant leak (commonly referred to a Freon, but these days usually R134A refrigerant). Some refrigerant has leaked, so you are still getting some cooling, but there is not enough refrigerant left to cool throughout the entire evaporator coils. This is NOT a repairable condition, as the coils are foamed in place and not accessable for leak repair. If this unit is under 5 years old (typical sealed system warranty) the manufacturer will most likely replace your freezer with a new one. If over 5 years, you are out of luck. Buy a replacement freezer.
Oct 12, 2008 | Whirlpool 10 cu. ft. / 283 liter Chest...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
158 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
