Question about RELIANCE ELECTRIC WATER HEATER
Hello ned some help are ou there? - RELIANCE ELECTRIC WATER HEATER
  • Danny Clark
    Danny Clark May 11, 2010
    what do you need?
  • 33 Answers
Ok, go ahead
Posted on Jan 07, 2010
Bosch hydropower 13h gas water heater not working
the tank is possibly full of gunk and the thermostat is not sensing the request for hot .flush tank if you can thru the bottom drain a few times if it is bad enough that ou get no water out then only option is to replace with a new unit
May 21, 2015 | Bosch Water Heaters
Radiators hot no hot water. Luke warm for a bit. Then back cold. Setting is past 'eco' just moved in not used to combi but surely this isn't right
check the diverter valve. look to see if when hot water turned on the small electrical switch at the end operates. If not then a ned valve or diaphragm
Apr 10, 2015 | Water Heaters
El code. can i fix it myself it.s a ideal boilr about 5yrs old
Y ou can fix it yourself it all depends on what is the problem.
Dec 29, 2014 | Water Heaters
How do I test the circuitry?
basically you ned to see if you are drawing 240 volts dc. use a volt meter at the electrical connection
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem Eco-180dvn. Error code 12
actually, does it give you a big rumble? if it does, then your problem is that the meter's btu's are not high enough and there's too litle gas getting to the heater so it's blowing itself out, basically. you'll need to call your gas provider and ask for them to bring in a higher btu meter. around 220,000 btu meter is best, so your furnace and gas stove(if you have one) dont take to much gas themselves, meaning dont get a 180,000 btu meter, because it would only be able to supply the heater.
Sep 19, 2009 | Rheem EcoSense by 7.4 GPM Tankless Water...
The pilot won't stay lit!! Before when this happened, we turned the gas down. It seemed it would blow itself out. Tonight...it doesn't want to light at all.
i should have seen that, sorry.
TDoes it go out when you turn the main control to on? If so, The thermo coupler appears to be not working. The thermo coupler is that bulb that is at the tip of the pilot flame. and has a small tube going to the main valve. It controls all the gas and shuts everything off if the pilot flame goes out, including the gas to the pilo. That is why you have to push the button to light the pilot. Ot bypasses giving the pilot some fuel. to lite. As mebtioned, if the thermocoupler goes bad nothing will work so I think changing it will solve your problem. If the coupler is not in the flame, try adjusting so it is and see if that helps Good Luck -Ned-
Sep 19, 2009 | Water Heaters
Water wizard 10P pilot light keeps going out
If the thermocoupler is defective the gas to everything is shut off. The coupler is the bulb that sits ib the pilot flame If it doesn't heat up it will sense no pilot and shut the gas off. They don't cost much and are easy to change. Good Luck, Ned
Sep 17, 2009 | Bosch & Tankless LP Hot Water Heater
What's up with My Bosch Hot water heater??
it sounds like a thermocoupler
its located inside the unit next to the pilot flame and should be screwed in next to the pilot button at the other end
May 28, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch 125BNG burners not firing
the diaphram is the pushing force for the gas valve to open, if you have a split or worn diaphram it will ned to be replaced.
Feb 21, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
RELIANCE ELECTRIC WATER HEATER Logo
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
