I have a 2002 Panasonic Model PT-47WX42F I have a red shadow in the screen. In other words when you see the channel info there is a red shadow of the same info. Whats broke? Mike
  • 647 Answers
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge between $200-$300
Posted on Sep 27, 2009
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic PT47WX54J is showing a red shadow behind words and pict
you need to go to your remote, look up menu. then select "convergence"...this will give you a "crosshairs pattern to align your "guns" ...it has three red, blue, and green.....try not to move the TV around too much....its knocking them out of alignment
Oct 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic Rear Projection Screen TV
you need new convergence chips, there are 2, part number stk 392-110, also you must check for burnt resistors, if you don't have very good soldering skills at least, you will need a tv repairman.
Sep 15, 2009 | Panasonic PT-53WX42 53" Rear Projection...
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
RED TINT
yOUR CRTS ARE SHOWING THE SIGHNS OF WEAR. ON THE FRONT OF THE SET BEHIND THE SPEAKER GRILL OR FRONT FACIAL. THERE ARE 6 CONTROLS 3 FOR SCREEN RED GREEN AND BLUE AND 3 FOR FOCUS RED GREEN AND BLUE. YOU CAN TRY TURNING THE RED SCREEN DRIVE CONTRIL COUNTER CLOCK WISE. JUST A VERY LITTLE BIT.
Jan 22, 2009 | Televison & Video
Double words
you need yo have your convergence checked
Oct 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
