Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
Is the lamp on a PT 45LC12 the basic controlling factor for brightness? Is there another control that will boost brightness?
  • haircomb Sep 29, 2009
    My real problem was that I lacked information on the TV because we misplaced the owner manual. I have since been on line and downloaded a copy of the manual from Panasonic.
    The picture was very dark when viewing most TV movies...almost as though the film was shot in the dark. According to the manual, I adjusted the picture and switched between cinematic mode and normal. In either mode the picture could not be improved much and the picture was darker in cinematic mode.
    Unfortunately, adjusting the picture brightness and changing the contrast didn't help much. The picture washed out, though it was somewhat better for viewing.
    I suspect the projection lamp is reducing its light output with age. If you have some other thoughts about this issue, I would much appreciate the input.
    Frankly, I'm considering replacing the unit with a plasma or LCD TV that requires no lamp replacements.
  • rahatfaraz May 11, 2010
    Solution chack on this site www.solve.tk
premtech
  • 934 Answers
SOURCE: Panasonic Rear Projection TV -dark picture
Javabean,
First off I think you meant Panasonic PT-51G44A which is an AP815 chassis. That unit has an all to common failure of the capacitor at C581 on the D board which is a 33uf/160v cap. Replace it and I think that will solve the problem..
Bill
Posted on Dec 11, 2007
Slinteriors
  • 8617 Answers
SOURCE: PT-45LC12 Problem after startup
When the lamp flashes 4 times this is what the error code means IC 2301 pin 11 has detected an LCD error which is caused by an error in the LCD power CBA. which means the lamp voltage has become more than 130 volts or less than 30 volts. Or the lamp current is more than 5 amps, or the lamp is cracked. Its one of thos 3 reasons that will make the lamp indicator blink 4 times. Hope this helps. If you need the service manual for this model you can get one emailed to you from the following link.
http://servicemanuals.vstore.ca/
Posted on Mar 31, 2008
SOURCE: Resetting lamp replacement warning
Turn the TV on and press recall to clear the warning. Then hold down the volume " - " button on the tv and the PIP (Play) button on the remote for ~ 5 sec
Posted on Apr 08, 2008
SOURCE: lamp reset
Pushing the - volume button on the tv and split above the play button at the same time for ten seconds or - volume on the tv and the split control button at the same time. The lamp reset message should come on.
Posted on Nov 24, 2008
TOM2-TOM2
  • 110 Answers
SOURCE: replacing a lamp for a panasonic pt 45lc12
Go here and download the "Datasheet"
http://www.mcmelectronics.com/product/P-TY-LA1500#?gclid=CPzAv4627poCFQhhnAoduxTECA
Posted on Jun 03, 2009
What remote is best for Panasonic PT-45LC12 ?
These are the universal setup codes for Panasonic TVs. You can select any brand universal remote control, which bears any one of these codes in its code list for Pansonic brand. Brand name of the remote isn't a matter. Check its code list, whether there is a code for Panasonic. That is all.
Setup codes for Panasonic are: 0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Aug 12, 2012 | One For All URC-3021 Remote Control
Pt-45lc12
It looks like a problem with a tube (projector light) I suspect the green one. Pay attention to flickering on the lights and post me the results.
Nov 01, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Lamp light out ?
Ck Fan behind Lamp first if it is OK then replace Lamp Look on E-Bay you can find lamps for as little as 82.00
Aug 06, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Pt-lcx65 lamp light blinks every four seconds Help!!
If it si the Temp Lamp, the unit is indicating overheating. Check to see filter is clean and vents are not obstructed.
Jul 02, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Lamp reset
Nov 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Apr 03, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Mar 31, 2008 | Panasonic PT-45LC12 45" Rear Projection...
My PT-45LC12 has picture and fan problems
More like lamp failure. Could be other things of course but start with the lamp cause it will need it anyway if has been a couple years.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it!
Jan 10, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT-45LC12 wont power up
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Feb 26, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
