Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
How do i install memory modules in a dell dimension 3000
This is Gabriel here . Please follow these steps to install the memory:
Lay the computer on its side so the system board is on the bottom of the inside of the computer. If necessary, remove a memory module: Press out the securing clip at each end of the memory module connector.
Grasp the module and pull up. If the module is difficult to remove, gently ease the module back and forth to remove it from the connector.
To insert a module, press out the securing clip at each end of the memory module connector.
Align the notch on the bottom of the module with the crossbar in the connector. Insert the module straight down into the connector, ensuring it fits into the vertical guides at each end of the connector.
Press firmly on the ends of the module until it snaps into place. If you insert the module correctly, the securing clips snap into the cutouts at each end of the module.Replace the computer cover.
Posted on Sep 27, 2009
Dell xps 200 installed new hard drive
I share information HDD back site small jumper available so you attach 1-2 and CD back side available jumper not connect any pin. Mother board auto find it and not any issue ok.
Thanks.
TechSupportMart Computer Support
Feb 14, 2014 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 will not power up. Solid amber lit stays on. Any help would be accepted.
  • If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
    • Remove and then reinstall the memory modules.
    • Remove and then reinstall any cards.
    • Remove and then reinstall the graphics card, if applicable
Refer to the link: http://support.dell.com/support/edocs/systems/dim3000/en/SM/adtshoot.htm#wp1043338
Jan 26, 2011 | Dell Dimension 3000 PC Desktop
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
Computer freezes after it boots up
There are couple of reasons for this problem: Virus, corrupted Operating system (try to reinstall OS), memory problem (try to install another good memory module), and the worst of all, defective motherboard/processor. Good luck
Sep 12, 2010 | Dell Dimension 3000 PC Desktop
Can I install one (1-gig) memory stick instead of 2 match pairs (only have one) this is to replace two 256 sticks?will it preform at 1 - gig memory
Yes.
The Maximum Total Amount of Ram Memory is 2GB.
(2048MB)
The Maximum Amount for EACH ram slot is 1GB.
(1024MB)
Ram should be installed in Slot 1, when using just one stick of ram.
This is the ram slot closest to the Processor.
The Processor reads ram memory that is installed in Slot 1, first.
This is Dell Support, and the main support page for the Dimension 3000 desktop computer,
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
In the list left-click on - Technical Overview
Now click on - System Board Components
Number 1 is Slot 1.
Note*
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate computer hardware components inside a computer.
Work on a table.
After you have opened the computer case, and BEFORE you remove that ram module from it's anti-static protective bag, TOUCH the metal frame of the open computer case. (Power unplugged from computer)
This will relieve your body of static.
Ignore the above if you are already aware.
May 21, 2010 | Dell Dimension 3000 PC Desktop
Can't open dell dimension 3000 to add memory
A tool-free side panel slides open easily to reveal a roomy interior with two free PCI slots. ... The Dell Dimension 3000 is an affordable computer designed to handle essential multimedia demands for the home user. The Dimension 3000 comes with the latest processor and memory technology, and won't break your budget.
May 14, 2010 | Dell Dimension 8300 PC Desktop
I have a dell dimension 3000 and i want to upgrade ram
Best thing to do is to go to www.crucial.com and run their system scan. It will tell you how much you have, how much it will hold, and what kind of RAM you need.
Thanks for using Fixya.
Oct 14, 2009 | Dell Dimension 3000 PC Desktop
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
I get "virtual memory low" message and cannot boot.
The real solution to this is going to involve spending some money to buy some new memory. It should cost about $30-50 depending on type and amount. 256Mb is not enough for Windows and other software to run. I would recommend buying at least 512Mb additional to add. Before you purchase open up your machine and look to see how many memory slots you have and how many are currently used. According to some specs on the internet, here is what you have.
Maximum Memory 2GB Memory Slots 2 (1 bank of 2) Install in pairs non-removable base memory 0MB Machine name: Dell Dimension 3000
CPU options: Intel Pentium 4 or Intel Celeron
Chipset: Intel 865GV Chipset
HD Bus: Ultra ATA/100
Front Side Bus options: 800MHz FSB
Memory Speed options: PC3200 DDR400 184pin SDRAM DIMM
Special notes: The Dimension 3000 has two different bus speeds each of which takes different memory. You cannot mix the speeds. Please check the speed on the memory modules currently installed, or use our "Check Your Computer" to find the correct module.
It is simple enough most anyone can do this themselves, and I could walk you thru it, otherwise you would need to take it somewhere, but my recommendation would be to do it yourself and simply ask me or others here for advice. Let me know if you want help to do this.
Good Luck!
b
Dec 13, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
105 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
