Question about Garden
I'm looking for a way to adjust the E-Brake on my Homelite 18" Chain Saw. Its model UT10830. The Saw runs great it just seems that the Brake keeps it from cutting properly by not allowing the chain to turn as fast as it should.... If I tie the brake to the handle, so that it takes the tension off of the brake, the saw runs and cuts great. I would think there has to be an adjustment for it somewhere, I just can't seem to find it!
  • 546 Answers
Remove the nuts that hold the bar & the screws that hold the cover on.w/ brake off,remove cover.inside cover you will find 'band' brake that surrounds sprocket assembly.if adjustment is provided,it will be at one end of the band.it's more likely to be an accumulation of sawdust interfering w/brake.also clean sawdust from chain oiler holes in bar,and around sprocket while you've got it apart.slacken chain adjuster screw to aid re-assembly,re-adjust chain
Posted on Sep 26, 2009
Looking for homelite model 3374 chainsaw
Pull the handle back to free position.
Jul 12, 2014 | Homelite Garden
HOW DO YOU ADJUST TENSION ON CHAIN FOR HOMELITE UT10519
Turn the tightener till the chain in the center of the bar at the bottom just hangs down about a 1/8"....
this will be good... too tight and the chain will not turn...too loose and it will come off...
that 1/8" is usually great for any saw...
heatman101
Mar 19, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Poulan PP4218AV 18" Chain Saw
Sounds loike its running lean, start by replacing the fuel filter on the end of the pipe in the fuel tank, if this does not help you need to richen up the mixture screws, unfortunayly you need a special toll to adjust the screws ( they have a spline, not a screwdriver slot ) the tool is part no. 530035560, once you have the tool unscrew the carb screws 1/2 turn on each and try again.
Feb 13, 2011 | Poulan PP4218AV 18" Chain Saw
Hi have a homelite ZR10580 chainsaw thats seems to be sending out too much chain oil but I don't see any adjustment for this?
1st. are you using the saw in a hot environment? warm chain oil will run easier than cold.
2nd. are all parts clean? remove the guard, chain and bar, clean the oil holes and contct points to reduce airlocks and allow oil to flow as it should.
3. Which oil are you using? I found Texaco Clingtex oil behaves well in all enviroments.
4. Have the oil pump checked... the seals on these saws arn't great and after a few years they can peish and allow too much oil through.
hope this helps.
Jan 13, 2011 | Homelite ZR10580 FactoryReconditioned 42cc...
Chain oil tank full, feed channel behind guide plate clear, but no oil going to chain when running. This is a homelite 16.
There should be a oil adjusting screw on the bottom of your saw next to the bar beside the oil tank. Some models actually has the screw inside the tank. Drain the tank to make sure there isn't any debris clogging the hole where the oil feeds to the bar.
One way to check to see if the bar is oiling is:
1. Start the saw
2. Put a board, piece of cardboard or an uncolored old shirt in front of the bar
3. Press the trigger on the saw to allow the chain to circulate around the bar.
4. While keeping constant pressure on the trigger, look to see if there is a vertical line of oil on the piece of material you have placed on front of the bar. If the saw is oiling you will have a vertical line. If not adjust the oil set screw accordingly.
Nov 15, 2010 | Homelite ZR10926 16 Chain Saw
Can you adjust clutch 16"homelite electric saw
There is not a clutch on an electric chain saw, it is direct drive when the electric motor ia activated. If the chain is binding it will stop the chain.
Nov 03, 2010 | Homelite Electric Chain Saw
Homelite chain saw model ut10522 engine starves
All late model saw engines (in the US at least) have special 'D' shaped jet screw heads that require a dealer-only special screwdriver. Check the fuel filter for plugging and the fuel lines for decay or other damage. If you feel the H jet setting is responsible, then you are stuck taking the saw to a servicing dealer for adjustment unless you are skilled at making such a tool yourself. Hope this helps!
Sep 09, 2010 | Homelite Garden
How to adjust the chain model 10655
See Chain Installation & Adjustment here: http://www.fixya.com/support/r4146814-chainsaw_chain_installation
No chain brake on your saw, ignore 1.
The adjustment screw is parallel to the bar. Look from the nose of the bar toward the engine the adjuster is the screw head just to the right of the bar (order follows):
1. - Engine,
2. - bar,
3. - guide bar plate (flared portion away from the engine),
4. - finally the clutch cover.
There is an illustration of most parts here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here:
Find "XL Chain Saw UT-10655", see "Housing & Handles" print.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 05, 2010 | Homelite Garden
What length chain is needed on homelite 360 proff. overall bar length 22" 19"from front of saw (extended)
What is written on the Bar? If your Bar is a 22" then the chain will be packaged for that length Bar. Make sure you get the correct model chain for your saw.
Jul 02, 2009 | Oregon Scientific Oregon Chainsaw chain...
Garden Logo
160 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
