The water does not drain
Follow the below diagnosis:
1. Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
Checking a drain hose
Note:
Disconnect the power source to your dishwasher before you conduct this or any other check. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Before you can check your dishwasher's drain hose for a blockage, you have to gain access to the hose. First remove the lower kickplate panel located below the door. This panel can be removed by removing a couple of screws that are located either above or below the panel. On some models, the dishwasher door has to be open to access and remove the screws, but then closed in order to remove the panel.
With the panel removed, locate the drain hose. It is connected to the pump located below the lower spray arm. The drain hose runs from the pump to the sink drain, or to the air gap on top of the sink. There is a second hose leading from the pump that is a recirculation hose. When you are checking the drain hose for a blockage, you should check the recirculation hose as well.
Place a shallow pan below the hose to catch any spills. Disconnect the drain hose form the pump by pinching the wire clamp with pliers and then sliding the clamp up the hose. Remove the hose from the pump assembly and wiggle the hose in various locations. This may help to loosen the blocked debris.
Try running water through the hose to loosen and unblock the debris. A garden hose at full pressure is efficient to use for this task. Now disconnect the recirculation hose and check it for blockage in the same manner.
Once you have successfully removed any and all blockages from either or both hoses, reconnect each hose to the dishwasher. Replace the clamps, and replace the lower panel. Reconnect the dishwasher's power supply and run the dishwasher to make sure it is running proplerly.
Replacing a drain hose
Note:
Disconnect the power source to your dishwasher before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Before you can replace your dishwasher's drain hose, you have to gain access to the hose. First remove the lower kickplate panel located below the door. This panel can be removed by removing a couple of screws that are located either above or below the panel. On some models, the dishwasher door has to be open to access and remove the screws, but then closed in order to remove the panel.
Place a shallow pan below the hose to catch any spills. Disconnect the drain hose form the pump by pinching the wire clamp with pliers and then sliding the clamp up the hose. Remove the hose from the pump.
Reconnect on end of a new hose to the dishwasher's pump assembly and the other end of the new hose to the sink drain.
Replace the clamps, and replace the lower panel. Reconnect the dishwasher's power supply and run the dishwasher to make sure it is functioning proplerly.
2. Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
3. Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
Examining a dishwasher belt
Note:
Disconnect the power source to your dishwasher before you conduct this or any other part examination. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Locate and gain access to your dishwasher's belt. It will be located behind the lower kickplate panel. The belt will be made of rubber and will be about twenty-five inches long. Some are clear in color, while others are black. The belt will be looped around a pulley at the base of the pump assembly and around a pulley at the base of the motor. The motor will likely be towards the right, with the pump assembly located closer to the middle.
You do not have to move the dishwasher away from the wall in order to access and/or replace its belt. You only need to remove the lower kickplate/access panel. There will be a few screws holding the lower access panel in place. Remove these screws to remove the panel. You may need to first open the door to remove the screws, but then close the door to remove the panel.
With the lower panel removed, the belt is fully exposed. Closely examine your dishwasher's belt. You are looking for signs of wear such as little cracks in the rubber and places where the belt may be stretched. If you find signs that your belt is worn, replace it.
Replacing a dishwasher belt
Note:
Depending on how much your worn belt is stretched, removing it might not prove to be too difficult. Replacing it, on the other hand, may require some tight maneuvering. You might want to try this tip:
1. Place one end of the above the pump pulley, around the pump housing.
2. Place the other end of the belt around the motor pulley.
3. Carefully roll the belt down from the pump housing to the pump's pulley.
Good luck.
