Question about Linksys Computers & Internet
Receiving very low signal from Siemens SE567 router using Linksys WUSB600N Adapter on my desktop, while my laptop with Intel Wireless WiFi link 4965AGN received full signal in the same room with the desktop, how can I fix it? Specifically speaking, I'm getting very high latency when playing World of Warcraft, I found out that I can use an application called Vista Anti-Lag to fix it, but it does not seem to work.
5 Suggested Answers
  • 70 Answers
SOURCE: USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Posted on Nov 26, 2008
SOURCE: 2WIRE wireless router/DSL from AT&T
I can fix it. You need a print server for your printer with usb or parallel cable port on one end and ethernet port on the other end. Connect the print server to router and printer, install necessary software driver it comes with and you would be all set. I have connected 1 usb and 1 parallel printer with router.
I hope it helps. My m/cs are identical to what you have as far as OS goes
Posted on Mar 17, 2009
mjjdesigns
  • 98 Answers
SOURCE: How do I force my built in wireless adapter to run
Does your router support the 5GHZ network?
My router supports dual-band at 2.4 and 5, and has separate SSIDs for each of them.
ie; network_1 = 2.4GHZ, network_2 = 5.0GHZ
So when I want the 5.0, I just connect to network_2
It's quite possible that though your wirelses adapter supports 5.0, that your router doesn't.
Posted on Mar 20, 2009
  • 1738 Answers
SOURCE: WINDOWS 7 latency problem
Make sure you allow in your firewall program. and you have ipx and spx protocal installed.
Posted on Nov 15, 2009
Find se567 manual
Try this link
http://setuprouter.com/router/siemens/gigaset-se567/manual-1055.pdf
Dec 05, 2012 | Siemens Gigaset Se567 54 Mbps 4-port...
My linksys wusb600n willconnect to my neighbors router but not mine
Try changing the channel number in the router settings and the wusb600n.
Set them both to the same number. It should tell how in the manual, If you don't have the manual for the wusb600n.it's here: Manual.
Feb 05, 2012 | Cisco Linksys WUSB600N Adapter Wireless...
My laptop works using my Belkin router, but my desktop will not connect to the internet
hello
your notebook has WiFi, which is radio frequency internet, it transmits and receives radio signals (frequencies) . Your desktop, most likely, does not support WiFi on its own , so you need to use RG45 cable , ethernet cable to be connected from your desktop to the router.
So in other words thsi is what happens with your notebook and the router.
  1. your notebook has built in wireless adapter which translates data into a radio signal and transmits it using an antenna.
  2. A wireless router receives the signal and decodes it. The router sends the information to the Internet using a physical, wired Ethernet connection, to your modem (supplied by your Internet Service Provider)
The process also works in reverse, with the router receiving information from the Internet, translating it into a radio signal and sending it to the computer's wireless adapter.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
Nov 15, 2010 | Computers & Internet
I have an Edimax 802.11/n wireless adapter installed on a desktop. We moved and the new location barely picks up the signal from my Linksys access point. In my previous house, it did okay, although it was...
check your edimax setting for the adapter if teh wireless signal is the same as the routers chanel the edimax defaul channel is always set to chanel 1 for the signal of its wireless and if your router has a different channel most probably channel 11 or 6 which is the most likely chanel that many use
May 22, 2010 | Computers & Internet
Linksys wusb600n on windows 7
WUSB600N version 2 will work with Win 7 using the Win Vista drivers.
You may refer to this link for compatible devices that work with Win 7.
You may also use the Win 7 driver - Ver.3.1.0.1.0 (32-bit, 64-bit).
Here is the link for the instructions to manually install the drivers.
Hope this helps!
Dec 10, 2009 | Linksys WUSB600N Pre-802.11n Wireless...
Wireless-g usb adapter fails to connect to router
if your wireless router has security enabled, as a first troubleshooting step you can try disabling the security. then see if the USB adapter can connect. IF it still cannot conenct check for the default channel on the router and on the adapter side.
Jun 03, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
" no card detected "
Go to router setup page and change the Wireless channel on the wireless setup page... Also check the compatibilty of Router & Card.
Feb 03, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
I just installed my siemens se567 wireless router nd I want to set up a wireless network to another computer using a linksys wireless usb network card. What must I do?
Hi tbopper, install linksys software. Follow the instruction. Disable your anti virus / firewall software. (temporally). Make sure the PC with the wireless card is turned on.
Than open My Network connections & run windows Set up a home or small office network. Follow windows instructions.
That's it. When you restart your PC your Anti virus software should enable it's self. Check your firewall is also back on, if it's included in your anti virus it will re-inable it's self. Since your running a wireless make sure you enable security & password, other wise anyone with a wireless can tap into your wireless signal slowing your bandwith down.
To test your linksys is correct. Open internet explorer. In the address window type in 192.168.1.1 & press enter. Your settings should show up. Tech support is free with linksys.
Good Luck & Enjoy!
Mike
Mar 31, 2008 | Computers & Internet
Linksys WUSB300N adapter not detecting wireless links
I am confused, you are using 2 routers, or you using their dsl modem/router? or your original??
Dec 29, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Computers & Internet Logo
208 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
