Internet pages display too big for monitor
When browsing the web, my monitor display was suddenly too large for the screen -- I adjusted the settings and was able to restore the first tab. However, when I click on a link (which opens in a new window) or open a new tab, the display is too large again. I have to scroll to the right to see the entire page. The initial tab is unaffected. I'm running Windows XP and I really don't know what to do! Please help if you can. THANKS!
  • 3 more comments
  • eeona Sep 26, 2009
    Thanks, James. That works to reset the initial tab, but when I open either a new tab or new window, the problem occurs again in the new tab or window. Is there a way to save the setting or apply it to new tabs and windows automatically?
  • 70 Answers
When you go to your homepage hold in "Ctrl" and use the whell on your mouse to resize. james. email me if this helped if not i will help more. james06_18@msn.com
Posted on Sep 26, 2009
Black background web pages
Step 1:
Web Pages That Do Not Display All Colors
Web pages that do not display all the appropriate colors have either a browser-related issue, monitor display problem, Windows comparability glitch or incorrect web pages Internet and HTML settings. More than likely, a setting dealing with your contrast ratio in Windows is the culprit. Once this issue is resolved, your web pages will display properly and accurately like they were designed to from the start.
Click on "Start" and navigate to the right pane and click on the "Control Panel." Click on "Ease of Access." Click on "Ease of Access Center." Click on "Set Up High Contrast" (one white and black box overlapping each other.) Check or uncheck "Turn on or off High Contrast when left ALT + left SHIFT + PRINT SCREEN." Click on "Apply" and close the Ease of Access Center. Press "ALT + left SHIFT + PRINT SCREEN" to turn on high contrast. Open your browser and go to a website to determine if color is restored to normal.
http://en.kioskea.net/faq/60-white-background-s-problem-in-web-pages
Feb 05, 2013 | Microsoft Internet Explorer 7
Fix my screen size
Click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system.
Also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size, larger size or custom settings
always click APPLY after making any changes.
Right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add to the Toolbar File Edit View Favorites Tools and Help
On the top of the internet page you should see some tabs file edit view favorites tools and help Click on the view tab on the drop down list you should see a zoom size %
Click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
There might be a menu button on the monitor where you can adjust reduce / expand the screen sizes usually located on the underside of the monitor of course this will depend on your brand of monitor.
hope this helps.
Nov 22, 2012 | eMachines D Computers & Internet
Display got big after search
click start control panel display desktop you can select a different desktop from the drop down list
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
depending on your monitor it might have some adjustment tabs usually located on the front underside of the monitor where you can centre your screen if needed
hope this helps
Jul 09, 2012 | Computers & Internet
My screen is connected to my computer--suddenly the screen shows pages too large and blurry. I can't recall how I resolved this problem when I first bought it and connected it to my PC. I'm missing...
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
hope this helps
Jan 07, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
What is the best setting on adell 24
The issue is relative to the native resolution of the monitor. in most 24" monitors the resolution is 1920 x 1200. When you get an application that is shown in the upper left corner of the screen, it is most likely set in a page frame of 800 x 600 or 1024 x 768. Also many web pages will display with large amounts of white space on one or both sides.
This you can do to help.
Set the DPI setting in display properties to 120 will help some making small type more readable.
Pages that are in Internet Explorer can be zoomed to appear larger zoom feature in bottom right corner of IE window (or CTRL & + and CTRL & - key combinations)
Oct 03, 2009 | Computers & Internet
Hp w1907 - web pages too large for monitor. I
You need to increase the resolution of your desktop.
Goto Display Properties->Settings
Jul 18, 2009 | HP w1907 LCD Monitor
Browser Enlarged
If part of the web page is not visible on the screen, you may have accidentally dragged it off to the side. Click the green button at the top-left corner of the web page to resize the window to fit on the screen.
If your screen resolution is set to 800 x 600 or less, most web pages won't fit on the screen. If possible, increase resolution to at least 1024 x 768 in System Preferences > Displays.
You may have accidentally hit Command (Apple key) and the plus sign (+) key -- this makes the text bigger. To reduce text size, hit Command and hyphen (-) key.
Finally, if Zoom is turned on in the Universal Access setting, you be looking at only part of the screen -- zoomed in like using a magnifying glass. Hold down Command (Apple key) and ALT key and hyphen (-) to see if this is on -- it will unzoom (zoom out) by one step. Turn this off or on in System Preferences > Universal Access.
I hope that helps.
Nov 18, 2008 | Apple iBook G3 Mac Notebook
Psp
You can go online with the PSP system and browse the Internet. To start browsing the Internet
  1. Check your PSP system set up:
    • Infrastructure Mode
      Make sure your PSP system is set up for Infrastructure mode.
      See Setting up Infrastructure mode for details.
    • Internet Connection
      Make sure you have an internet connection and your PSP is within range of the wireless access point (or hotspot).
      PSP®online connectivity requires internet service and network devices, suchas a DSL or cable modem and a wireless router - for example, a Wi-Fihotspot at a café or a wireless local area network (WLAN) in your home.
    • System Software
      Make sure you've got the latest System Software.
      Requires PSP system software version of 2.0 or higher. Visit PSP System Software Update to download and install the most recent version.
    • WLAN switch
      Make sure the WLAN switch on the left side of the PSP system is turned on so that the PSP system can connect to the internet.
  2. In the XMB™ home menu select icn_network.gif (Network) > icn_www.gif (Internet Browser) and press the icn_btnx_color.gif button.
  3. Use the up and down buttons to select the address bar and then press the icn_btnx_color.gif button to display the on-screen keyboard.
  4. Enter the address for the web page you want to display, select Enter and then press the icn_btnx_color.gif button.
    For more information, see Using the On-screen Keyboard.
  5. Select a connection and press the icn_btnx_color.gif button.
  6. The web page is displayed.
  7. To hide the on-screen menu, press the icn_btntriangle_color.gif button.
To close the Internet connection:
  1. With a web page on the screen, press the icn_btncircle_color.gif button.
  2. Select Yes and press the icn_btnx_color.gif button.
  3. The internet browser will close.
If you have issues connecting to the Internet, you may wish to troubleshoot your Infrastructure mode connection.
Sep 14, 2008 | Sony PlayStation Portable (PSP) Console
Hello i purchased a philips 20PFL4122 lcd tv/pc monitor and i have a problem when i set the resolution on my pc to 640/480 as instucted in the user manual the pages are to large to fit the the screen when...
I have bad news for you.
The monitor you bought (Great Price by the way) is working exactly as designed. The problem is the 640 x 480 resolution. Almost all internet content now days is scaled for either 800 x 600 or 1024 x 768 resolution. This is why every time you open a page you have to pan both left and right and up and down to see the entire page.
LCD monitiors are designed for a fixed resolution unlike CRT (TV Tube) monitors that can display different resolutions with equal clarity. This is why when you go to a higher resolution the screen is almost impossible to read.
Since your optimal resolution is 640 x 480, that is the only resolution that displays clearly. That is great for a TV, but sorely lacking as a computer monitor. It is also why the monitor was such a good price (a definite case of you get what you pay for here). So the unfortunate answer is that the monitor will never be satisfactory when used on the internet.
Jul 31, 2008 | Computers & Internet
Monitor image size
There is nothing wrong with the monitor, the issue is that the web page you are looking at is designed for a lower resolution than you LCD is set for (Web pages are normally designed for 800 x 600 or 1024 x 768) you like have a wide aspect ratio monitor.
As I sit here writing this on my 12" wide aspect LCD I have a 2" wide white space on each side of my screen due to my 1280 x 800 aspect ratio.
The issue is one of WEB PAGE DESIGN not the fault of your computer video settings. The web page is written using page frames and fixed aspect ration settings to ensure that the page displays properly regardless of monitor type.
If you had a high end LCD (WUXGA 1920 x 1200), the web page would fill the upper left 1/4 of the screen.
If you lower the resolution of your display, then you'll have fuzzy icons and text, so essentially, get used to it.
Eventually, wed design will catch up with current display technology.
Jul 24, 2008 | Computers & Internet
Computers & Internet Logo
478 people viewed this question
David Payne
David Payne
