Question about Freezers
How do i hook up the water supply. witch is the inlet and outlet?
  • 28 Answers
Most newer units have a brass inlet on the valve and a plastic outlet. Older modles have a plastic garder hose type fitting for inlet and same smaller plastic thread for outlet Some models have push in connectors called John Guess fittings the do not require threading.
Posted on Sep 27, 2009
3 beeps every 3 seconds
This usually occurs when there is a water supply issue. If you remove the front cover and expose the right side of the unit, you will see (at the top right) a panel with a black button on it about 1/3 the way in. USE A FLASHLIGHT to locate it.... there is an electrical shock hazard here.
Push the button and the beeps will stop. If the warning recurs, check for water pressure to the unit.
First, if you have a filter system, crack the nut at the entry to the filter just enough to see if water is present there. If not, go to the source and check the angle-stop... change it, or open it, as required.
If you have water at the filter inlet, do the same thing (after tightening the nut you loosened) at the outlet. No water?..... change the filters. Water present?... do the same at the entry to the ice machine.
Water at the entrance? Turn off the water and remove that fitting to expose the inlet solenoid valve and examine the strainer. If clogged, remove and clean the strainer.
Beyond this, you will need a technician to deal with the issue. Call the Hoshizaki factory at 1*800*438*6087 to find a factory-authorized service company in your area.
Jun 14, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Never hooked up one green line running bottom to top with plastic nuts . one valve at bottom looks like a tire valve stem. is this the inlet water line hookup
Do not hook water to the "tire valve stem"! That is probably a freon access valve. Hooking water to that will ruin the refrigeration system.
Oct 31, 2009 | Freezers
Hello!ad my black glass fridge freezer delivered today with ice n water dispenser and plummer cudnt work out instructions if the water filter canister goes on the inside or out! also where does the pipe...
Post your model number for filter help. The water supply hook to the water inlet valve on the back, Usually near the bottom. It has a fitting where the incoming water will fit. You may have to remove part of the cardboard on the back to get to it.
Oct 28, 2009 | Freezers
Can get water from the main water line but can't get water up to the ice maker help
HI. The inlet valve is suspect in this case. I recommend to inspect this device for damage. replace if necessary.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
NOTE:- Make sure the inside line is not frozen over before preforming the inspection of the inlet valve.
Oct 19, 2009 | Frigidaire Freezer Refrigeration White...
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
Have a comercial ice machine ,dont know how to hook up!
You gonna have a drain for the reservoir to clean the unit and a drain for the ice bin and then a connection for inlet water. The water valve is the key. Look for it.
Aug 27, 2009 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
I recently moved my Maytag refrigerator model MSD2554F from on part of the kitchen to another. It took me several days before I hooked the icemaker back up. I also replaced the water supply line for the...
Hi, Remove the line to the icemaker from the inlet vavle and blow through it. You can tell if it is blocked or not.
It might have frozen in the inlet tube through the wall of the freezer.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Freezers
ICE MAKER NOT MAKING ICE, WATER NOT FEEDING INTO ICE MAKER
you may have a frozen inlet tube coming in to the ice maker. This is caused from a bad water valve and you would need to replace the water valve.
Apr 02, 2009 | Frigidaire Freezers
Hoshizaki ice machine model KM-450MAB water runs constantly even on freeze cycle. Water is very cold.
Hoshizaki machines have a water inlet valve that can stick in the open position. This will cause the machine to do silly things. If you can turn the machine off and you can still hear water running, the valve is stuck open. It is an easy fix. Water valve only has 2 wires going to it and 2 water lines. One inlet and one outlet. Just turn off water and kill power at the breaker before doing any work.
Hope this helps and good luck.
Try Rick and Restaurant Parts and More in Ohio for a replacement valve. 1-888-814-1110
Apr 01, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Freezers Logo
51 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
