Question about Canon PIXMA iP1600 Printer
I took my pixma canon printer apart to clean the ink absorber pads. Now I can't get it back together again! I have a spring, white part, and silver thing left and can't seem to find where they belong. Any ideas?
SOURCE: How to open Canon iP3000 and remove absorber pads?
my computer see the printer as ip3100 & ican`t load my driver
Posted on Mar 12, 2008
SOURCE: Canon Pixma ip1300 Ink absorber is full what can i do
another solution for a quick override is to unplug the power lead from the back of the printer. With one hand hold down the power button on the printer whilst simultaneously plugging back in the power lead. When the light is back on, take your finger off the power button. You may need to press the power button once more, but this should 'override' the problem until the next time you turn your printer off.
Posted on Apr 16, 2008
SOURCE: Waste Ink Absorber is full In Canon Pixma IP3300
please give me resetting soft for canon Pixma iP 3300 printer.
Posted on Oct 06, 2008
xptareq2000
  • 1447 Answers
SOURCE: canon pixma mp160 ink absorber is full
e75ff09.jpg this the reset wast ink please follow it step by step
Posted on Sep 06, 2009
leethedeuce
  • 4472 Answers
SOURCE: ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Posted on Nov 05, 2009
Canon Pixma MX300 ink absorber cleaning video ; how can I clean the ink absorber?
When the ink absorber pads are full, you can easily remove and clean them on most Canon printers. Fill a large bowl with warm, soapy water and set it aside. Put on the rubber gloves. Open the ink cartridge compartment.
How to Clean a Canon Ink Absorber ' Chron.com
smallbusiness.chron.com/clean-canon-ink-absorber-57609.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Canon+Pixma+MX300+ink+absorber+clean
Nov 26, 2016 | Canon Office Equipment & Supplies
Tip
Canon PIXMA printer ink absorber full
if the printer shows ink absorber full on display you have to firsst physically acess the ink absorber pad then clean it up by removing the excesses ink from the pad ,follow the step below to do this
STEP 1:
- Disconnect printer from AC power supply
STEP 2:
- Press and HOLD the POWER button, and connect printer to AC power
Power up with the cover open until the head moves to the left side then disconnect the power cord so that the head is positioned away from the pads. raise The two pads easily with a pair of sharp tweezers and the rinse in running water. it will become white again and can be blotted with paper napkins then air dried in a warm location(may be in an oven) . cleaned the wells in the rubber holdet with cotton swabs before returning the two pad.reset then power back
on Dec 19, 2009 | Office Equipment & Supplies
How to put the the springs back in the canon P1500 after cleaning ink waste absorbers?
i just lined up the main housing, put the 2 screws in the front (did not screw in the 3 side screws) ( tried it when the housing was off the springs would just fall down)
just slide the springs in after it is screwed in the short side fits into the white plastic you will see grooves where it lines up on the white plastic piece, the long side of the spring hooks on to the back metal hook on the other side the coil rests in the middle of the prongs
Jul 06, 2014 | Canon PIXMA iP1500 InkJet Photo Printer
Does the Canon Pixma MP190 have a waste ink absorber in the bottom back right of the unit in addition to the 2 pads where the print cartridge sits? If so, then how do you get to it to clean it? Is it...
I just did take this same machine apart. The second ink absorber pad jumped out as I was pulling on the rubber cradle and stuck to something, being wet with ink, and I could'nt find it. My hand were too big to do the job sucsessfully, Time for a new one!
Sep 08, 2013 | Canon PIXMA MP190 All-In-One InkJet...
Waste ink absorber full
Open your printer.
To protect hands from Ink wear thin latex (or similar) gloves
Locate the Waste Ink Pads on the inside of your printer
. They are on the right hand side and are quite small.
You can remove the pads and the holder with a gentle pull
Using a tissue, soak up as much ink as possible and clean the area around the waste ink area
There is one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dried and placed again. Be careful and patient. This is no understatement. Take a photograph (even with your cell phone) so you can trace back your steps. You also need to take care as you lift the slide/carriage. Below this you find 5 little springs.
Carefully replace the holder and the pads
. Close printer.
Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power
Release the power button
Press the power button again
Mar 03, 2011 | Canon PIXMA iP1800 Printer
Waste ink absorber is full. what should i do? so i can use back my printer
Siijakiah, I have successfully taken apart and cleaned the waste ink absorber. My problem came when I was putting it back together. Can't find where the two springs under the ink cartridge rest go.
There are two small hard pads on the right hand side under the ink cartridge rest that are fairly easy to clean (just press gently with a tissue until no more ink comes out) as long as you don't drop them.
There are also two large pads right at the bottom of the printer that need cleaning and this requires that you take your printer apart. I can describe how to take it apart and clean them. I can also describe how to get it nearly back together.
If there is anyone else out there who is kind enough to explain/describe where the springs go, I am sure I would not be the only grateful person.
Aug 18, 2010 | Canon PIXMA iP1000
How to take apart Cannon PIXMA iP3000 to clean the waste absorber
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
May 22, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Ink Absorbers almost full in Canon Pixma 1500
The absorber pad on the iP1500 is located just inside the front cover. It's about 3/4" in front of the white rollers and runs the width of the rollers. I can't imagine what video would show taking the printer apart. Just pull it out (carefully). The pad can be cleaned in the sink, dried, and replaced. Note that this won't change the message you will get. You need to do the hard reset that you have probably seen elsewhere (hold power button down while plugging in the printer).
Apr 30, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA ip2000 assembely
Shaun,
Please click the below mentioned link to visit Canon PIXMA iP2000's manual page:
Canon PIXMA iP2000 Manuals
Thank you
Aug 25, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP1600 Printer Logo
32 people viewed this question
old marine
old marine
