Question about Cobra 29 LTD CB Radio
My cb mic got pulled apart in truck accident how do i color code the wires to connect them back to the harness, that plug in the mic
  • 86 Answers
1=shield
2=audio
3=TX
4=RX
maybe this will help.
Posted on Oct 14, 2009
CB Uniden 4-wire mic to a Uniden 510 radio how to wire color codes please
look up microphone wiring diagram for your cb and mic. more than one way to wire, depending on mic and cb having 4 or 5 on plug end. write down mic numbers and cb plug numbers. if audio on mic is 3 and cb is 4 put 3 on 4 pin check each wire. using power mic make sure red and black wire are on the right pin, can damage radio or mic or both.
Feb 11, 2018 | Uniden Radio Communications
2014 triton mn. How can I connect 7-pin trailer socket into existing wiring harness?
the simplest way to do this is to go to a tow bar installer shop and buy the harness ( around $25.00 aud)
it is a simple action of pulling a harness plug apart and inserting a piggy back plug in the connection
the wires for the trailer are properly installed and all you have to do is wire the plug connection according to the wiring diagram that came with the plug
Feb 10, 2016 | Cars & Trucks
Wiring code super star mic to rca copilot 14T 303
The colors shouldn't matter.... check the mic switch. and follow your wires to the mic plug. the common wire is normlly the ground to allow RX then when pressed for TX the other should then be your audio which will be connected to the mic element.. using this method you can wire any mic to any radio.. pending the mic element ohm value impedance is correct for the radio.
Dec 06, 2015 | Radio Communications
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
Cb radio trc446 rewiring microphone color coding
if you pulled it completely out you may have a problem . Trial and error is all I can tell you.Get a volt meter and check the mic pins on the radio . Ground one lead and touch each pin for ohms the first one to make noise is the ground. then touch the ground with one lead and touch the next pin and the next . now if there is any left over wire on the plug you can rewire it , then go from there.
Mar 25, 2013 | Radio Shack 40 Channel Cb Radio Model...
I need a wire harness for a Cobra 40X CB or at least a description of how to hard wire.
I'm not sure I understand what you mean by wiring harness. If you are trying to wire it to power, and need the power wire, they are widely available. Its a universal plug for cb radios.
Ebay for around $5 search for CB power wire.
Truck stops usually carry stuff for cbs and they will most likely have one.
If you are talking about wiring the mic..... Just buy a mic for it already wired to the plug.
Dec 05, 2009 | Cobra Radio Communications
Have a33hml sometimes does not transmitt or rec
take apart the mic where it plugs into the radio.
there are probably loose wires.
make sure to mark each wire where it is hooked up to the mic pins before you start messing with it. Example: red #1..black..#2 ETC ETC.
the mic plug has numbers on it and the colored wires go to certain numbers on the mic plug.
Oct 23, 2009 | Galaxy Radios DX-33HML 40-Channels Base CB...
I need to rewire my roadking 56
Hi and welcome to FixYa,
Pinout and mic wiring as follows:
  • 1 - mic - white
  • 2 - RX - black
  • 3 - TX - blue
  • 4 - Ch Up/Down - NC
  • 5 - GND - bare/red
  • 6 - Vcc (+13.8VDC) - NC
Good luck and thank you for using FixYa.
Feb 11, 2009 | Magnum 257 CB Radio
Wires pulled off a cobra mic 75wxst 5 pin connector
1) violet 2) blue 3 ) shield 4) yellow 5) grnd Violet inside the mic is the power wire . Blue and yellow are the internal and external speakers. the other wires are to the antenna
Dec 26, 2008 | Cobra 29 LTD CB Radio
Converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
Oct 06, 2008 | Midland 1001Z 40-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
211 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
