Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
The brushes are not moving and cannot push forward easily
    Scholar:
  • 190 Answers
You will wish to remove the four bottom plate screws, on the corners of the brushroll pocket, remove the agitator bottom plate, and look and see if the two belts are still connected, or broken.
Posted on Oct 03, 2009
Dyson brush bar stops when I move forward
Make sure that the brush does not have lots of hair etc jammed around it. If there is anything that will cause resistance to the brush bar turning, a sensor will immobilise the brush until it is clear. Be careful how far you strip it back to as there may be warranty issues if you do more than undo the bottom with a penny, so you can use scissors to cut away at the hair or carpet fibre entanglement. Good luck
Nov 24, 2013 | Dyson DC25 Animal Bagless Upright Vacuum
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Canister vac - the motor on the cleaning head cuts out while vacuuming. does it as you draw back the head while cleaning , goes off momentarily and ten when pushed forward engages the motor again. this...
Unplug the vacuum then pull the bottom off the head and clean the brush. Check for debris on the brush and around the ends of the brush. Insure the brush moves freely. Check the motor by turning it by hand to see if it rotates freely. Check the belt to sdee if it is tight. When belts get old the will sometimes stretch and won't work properly. Hope this helps.
Jan 03, 2011 | Vacuums
Our Riccar SupraLite Upright Vac used to glide across the floor so easily, but now we have to push it pretty hard. This just recently started. What can be wrong?
Suggest you check the wheels to see if they are moving freely. Also check the beater brush to see that it is moving freely. Be sure the belt has not broken. If it has, replace with a new one. Also take the time to clean the beater brush of any debris and spray a little WD40 on both ends of the beater brush axle.
Sep 12, 2010 | Riccar 8955 Upright Vacuum
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Oreck upright hard to push
If hard to push, only a few things to check:
(1) Rear wheels will get hair or thread wrapped around axles, dust, etc. and be hard to turn. Make sure each wheel turns easily.
(2) Small wheels on newer models (since about 1997-98) toward front are worn, missing or have same problem as item 1.
(3) Brush roll not turning. The brush roll actually helps pull this unit along the floor, as it rotates in the "forward" direction. If the belt broke, and you do not realize it, it may suddenly seem harder to push.
Oct 11, 2009 | Oreck XL2000 Bagged Upright Vacuum
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
Hopping - jumping - skipping - bouncing
It could be that you have the brush settings wrong for your carpet type. Check if the brushes are on number 3, if so, try dropping them down a notch or two and see if that does it. I think that the brushes when spinning spin towards you, so when pulling the vacuum back, the brushes are helping to drive, when pushing forward, you are pushing against the brushes. If the brushes are sticking out too far, it could cause bouncing/jumping. HTH :)
May 23, 2007 | Kirby G6 Bagged Upright Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
