Question about OKI MICROLINE 5590 Matrix Printer
Escape sequence for reverse feed
Does anyone know of a escape sequence in vba to reverse feed my jobsheet by at least 2 inch. My jobsheet at the moment is going too far after i print 1 out and i have to manually re-aline the sheet every time i print.
Thanks
  • mark hudson Dec 18, 2007
    looks like the manual ive been using, im very new to this and have tried some of these codes. I can only seem to get my command to work after a tear. ive been using the command
    Private Sub Command1_Click()
    Open "lpt1" For Output As #1
    Print #1, Chr(10);
    Print #1, Chr(27); Chr(106); Chr(180);
    Close #1
    End Sub
    tried changing the codes around but with no luck
  • mark hudson Dec 20, 2007
    pasha19,
    i managed to get this working without the codes,i changed the size setting in the menu on my printer and created a custon size page in my server properties. Just need to swap it over to the network now. Thank you for your comments and your help.
  • 556 Answers
Manual
Page 73 has two commands that may be of interest
Form Length
And
Line Feed, Execute, Reverse
Hope this helps
Posted on Dec 17, 2007
  • david Dec 18, 2007
    Did you consider using form length?
    Note working by lines and not inches is probably preferable because you have control to the line width and not the inch.
    If you are running 8 lines per inch on a default 11 inch form and form feed is taking you too far -- 88 lines. 9 inches is 72 lines. After opening the printer issue the form feed to alter the number of lines to 72. Adjust the number as necessary until it is right
    ESC C 72
    For 6 lines per inch or 66 lines on an 11 inch page. 9 inches would be 54 lines
    ESC C 54
    Then the page should not overshoot the mark and you need not back up
Does anyone know the head torque specs and tightening sequence (if necessary) for B&S 42A707 Type 2238 E1 17 HP? Thanks.
briggs has service manuals available on their website... take those numbers and search... and yes. they have a sequence and a torque spec. which is 160 inch pounds
Oct 25, 2014 | Briggs & Stratton Garden
Where is the crank position sensor located on the 2002 Ford Escape? Will I need a rubber O ring or paper spacer?
The Crankshaft Position Sensor (CKP):
4 CYL - located on the front of the engine, near the flywheel end of the block. remove exhaust manifold, disconnect electrical connector, remove bolt. installation is reverse of removal, no gasket req'd. torque to 62 inch-pounds
6 CYL - located next to crankshaft pulley - remove right wheel, remove lower right splashshield. disconnect electrical connector, remove bolt. installation is reverse of removal, no gasket req'd. torque to 89 inch-pounds
Dec 17, 2010 | 2002 Ford Escape
How to stop calibrating soo much?
There is no way to get around the recalibration for different sizes of label, you must do it at every different label height, The callibration only sets the label height/length, so try doing the same length labels in sequence.
Oct 22, 2009 | Zebra 105SL Thermal Label Printer
Removing leading zeros from barcode???
Prefix/Suffix Dialogs
The Prefix/Suffix Dialogs allows configuration of DataWedge options.
Two data entry fields are used to display and allow entry or editing of prefix and
suffix strings. The prefix string, if present, is transmitted before the data for any
barcode scanned. The suffix string, if present, is transmitted after the data for any
barcode scanned.
The following checkboxes are used to display and allow modification of various
DataWedge options:
Allow escapes in prefix/suffix (default = disabled)
Enabling this option allows escape sequences to be embedded in prefix and
suffix strings. Escape sequences allow non-textual data to be transmitted as
part of the prefix or suffix string. All escape sequences begin with the backslash “\”
character. The supported escape sequences are:
\b Backspace
\f Form feed
\n New line (line feed)
\r Carriage return
Apr 14, 2008 | Symbol MC70
VBA Password
Can you read the code at all?
If yes, try copying the code to a new VBA screen and pasting it in.
Do your changes in this screen and save it as a Macro, then delete the original.
Note: I use a blank password on all my protected documents - not real good security, but easy to remember and others don't know that it is to be left blank - so it foils a lot of people. I use the password only to protect the formulas and script from being changed accidentally by the end user - not to prevent anyone from "stealing" my code.
VBA passwords seem to be difficult to crack and the programs to do so seem to be quite expensive for a one time use.
Have you thought of just rewriting the VBA script? Remember, you did it once and went through all the problems of working out the sequence etc so much of this might come back to you and save a lot of time over the original exercise.
Good luck.
Mar 26, 2008 | Microsoft Excel for PC
Sending Reverse Line feed to Epson LX-300+II USB printer
Hi Shery,
I went through the manual of LX300 printer series.I believe that if u read that manual, you can Fix the problem as it has all instruction about the Reverse feed and pull tractor mechanism.
Download Manual
http://ftp.epson.com/pdf/lx300p/lx300ppg.pdf.Any issue contact me.
Thank you
Riz (zyrixdown3@gmail.com)
Feb 11, 2008 | Office Equipment & Supplies
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
Jan 28, 2008 | Computers & Internet
Excel vba password recovery
You can but you will need software. Search for google for VBA password recovery tools. Search for the appropriate crack you have it all . .
Dec 30, 2007 | Microsoft Excel for PC
OKI MICROLINE 5590 Matrix Printer Logo
256 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
