Question about Nikon D80 Digital Camera with 18-135mm Lens
D80 - R-09 and F__ flashes and I cannot take any shots
I get an message R09 on my Nikon D80, I know R09 means the number of shots left in the buffer, but the camera has been like this now for 6 hours. Is there a fault with the buffer loading shots to the card? I have the kit lens (18-135) on the camera.
Nikon D70 is freezing up. I have no idea what I may have done but when I push the button to take a picture nothing happens and r09 flashes
r09 is just the camera estimate od how many shots you have left on your memory card. For the other, Use fully charged battery , Turm ca,era on and re,ove battery while at same time holding shutter for a[[rox 3- seconds. Re[lace battery, then turn camera off.on. If that does not do it, turn camera on and press reset button on bottom of camera (page 200, I believe, in tghe users manual
Jan 29, 2011 | Nikon D70 Digital Camera
I've got the R09 error (or R12 etc...) with my Nikon D70. How do I reset the buffer memory of my camera a.e. how do I get my camera working again? please advise
an r # (r09 or r12) is the cameras estimate of how many remaining pictures can be shot on your memory carde. It is not an error. The camera works, does it not?. If something else is happening let us know.
Oct 18, 2010 | Cameras
My nikon D80 w lens Af 18/135 Has Err sign when press the shutter and also sign r09 on the no. Of exposure.. Urgently need help
Both items can be found in the D80 manual.The r09 is found on page 36 lower. It is the number of shots the buffer can handle. The Err is not a good thing. Turn off the camera, remove the battery then replace it, turn on the camera reset to factory bottom of page 129.
Aug 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
Hi K akima...have followed your advice, but no luck. When I go to continuous mode, it only lets me shoot a single shot, the display briefly reads r 08 then returns to r 09 again. I`ve tried my other lenses...
nikon r09,r11, etc . it mean memory buffer of your camera. memory buffer is a temporary memory for your captured images before it store to memory card.
if r00 it mean, you can't take a picture, even 1 picture... that because the camera buffer memory is full.
the number of memory buffer will also drop if noise reduction on
Feb 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
My d 80 gives an err message on the lcd and r 09 is flashing on it, the shutter just clicks and makes the sound but no picture taken, i am frustrated please help
The r09 just tells you how many pictures you can shoot before the internal memory buffer is full. It's not an error message2_bing.gif. If the camera isn't taking a picture, then it's something unrelated to the R09 message. If the shutter clicks, then it probably IS taking a picture.
Jan 14, 2010 | Nikon D80 Digital Camera with 18-200mm...
Nikon D80, how do you turn off the r09, r11 and/or r17 alert (depending which Image Quality setting I have the camera set to)? I have sent the camera back to Nikon twice and twice it has come back with the...
The r09, r11 or r17 just tells you how many pictures you can shoot before the internal memory buffer is full. It's not an error message, and I don't think there's any way to turn it off.
Sep 29, 2009 | Nikon D80 Digital Camera with 18-135mm...
R09 shows up when I try to take a picture. Cannot access preview screen. Camera seems frozen.
R09 or R07 etc. is not an error message. In Nikon lingo ERR is the one you need to worry about. The RXX refers to the approximate amount of shots left in the buffer in the camera. Not a ptoblem. You may be trying to take pictures faster than your memory card / camera buffer can handle.
You can try a fster card like 266, but you may find that the camera is also your limitattion.
If you make no changes at all, the camera buffer will eventually clear and you can again takes pictures.
May 11, 2009 | Nikon D70s Digital Camera
In brackets I have the number of shots 529 however Nikon D50 SLR
The r09 is merely telling you how many more shots you can take in a burst before the buffer fills up. It should not affect operation at all unless you take nine more pics in a burst.
Are you trying to change controls while pressing the shutter button? What controls?
Mar 26, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon DX40x not taking pictures
First, the r09 refers to the amount of memory buffer photo storage is available. That's to say that 9 photos can be stored in the memory buffer, while the latest pictures are being written to the slow camera card. It's bursting 9 photos. Depending on your image quality and type, this will be a different number.
Second, make sure you are in the P or Auto mode while testing, or clarify what mode and settings you have. A picture won't take on my D300 if my lighting is too low for my current settings.
Dec 23, 2008 | Nikon D40x Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
501 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
