Question about Canon GL2 Mini DV Digital Camcorder
My GL2 only works when I turn it on to playback mode. When I try to turn the camera on in camera mode, it doesn't work. What could the problem be?
There is a simple solution to that... You see under the 'card-tape' switch? There's the red button for recording... attached to that button the is a switch that says 'tandby or lock'.... if you have it in 'lock' it will not let you go to record mode, you have to change it back to 'standby' and that should solve your problem.... Anymore question just e-mail me at Jacob.Bahling@Live.com and I was wondering if you had a copy of the installation CD I can buy or have.... or maybe you could tell me where to get it? Thanks.
Posted on Oct 27, 2009
You've probably got your camera in Lock mode. Make sure the switch by the record button on the side is pointing to Standby and not Lock.
Posted on Oct 04, 2009
I loaned my camera to someone. Now the viewfinder is black, however it is recording. I just can't see what I am recording.
It is set to read a tape, It is set to standby.
Posted on Nov 04, 2009
Does the sd card for a cammon gl2 have to be formatted
Yes, it does and should be done in the camera and each time you download the images just to keep it in best operating condition. Switch to VCR/Playback mode and reformat the card from the menu option (see your manual). Also note that if you're having issues with the camera reading a card be sure it is one that can be used and does not exceed the GL2's maximum card size (though I don't recall what that is).
May 09, 2014 | Canon GL2 Mini DV Digital Camcorder
My canon gl2 lcd screen and viewfinder black
Same thing happened to me. No display, no menu, no S-video output while in camera mode, but in VCR mode all was OK. Turning power off and on did not help until I also disconnected the AC power adapter. BTW, Mr. Riggins did not read the question before he answered.
Nov 25, 2012 | Canon GL2 Mini DV Digital Camcorder
I am experiencing a problem with playback. A few times I have tried to play the tape to capture and the counter will not work and the screen stays blue?? I used the head cleaner on it and it played...
This is usually caused by a severely oxidized video drum. If you 've tried running a cleaning tape through the camera with no results the camera will need to be serviced by a qualified technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 06, 2011 | Canon GL2 Mini DV Digital Camcorder
Playback problem DSR 11
if you plug & unplug cable after turning off ,perhaps you can the conector firewire on the vcr inside there are 4 yellow cables if not the conector defect.try to push the cable firewire litle up down side just to make sure
Apr 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Camera GL2 Zoom Noise Problem
the sound is either the tape reels spinning or the zoom can you possibly send me a copy of the sound mattgandersn@aim.com
Feb 17, 2009 | Canon GL2 Mini DV Digital Camcorder
Red light blinking
i was filming, and i tripped and my gl2 hit the ground. it hit the battery kind of hard and now it wont work properly. now when i turn it on, the power light blinks red or green, depending on playback and recording mode. i want to know how i can fix this.
Dec 18, 2008 | Canon GL2 Mini DV Digital Camcorder
Color registration on Canon GL2: purple recorded as blue
I have the same problem on my Canon XH-A1 and sony TRV33. I wonder if this problem applies to all camcorders?
Jan 26, 2008 | Canon GL2 Mini DV Digital Camcorder
Zoom goes into automatic pilot
Try take battery off camera while operating recording mode, amd put it back without turning off camera. I really do not know why this happend, but this solved my Canon mvx330i "by it self zooming" problem. try turn on digital zoom in meny and take of battery...
Nov 08, 2007 | Canon MVX330i Mini DV Digital Camcorder
Canon Gl2
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 shuts down automatically while in record mode
Turn off the power saver mode. I did it and it works!
Apr 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
354 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
