Cracked discharge hose on GE washer
I have a brand new GE washing machine model WJRR4170G with a leaking hose. I called GE and they can only send a technician out in three weeks to replace the hose. I can replace it myself if I have the instructions or a diagram.
Please send me diagram or instructions.
Thank you.
aflocken@pgasd.com
  • 2 more comments
  • xyxyxyxy Dec 17, 2007
    Try model # WJRR41700G
    model # WJRR4170GWW
    What about model # WJRR4170GWW? I am fairly sure this should be the correct number now...
    Drain hose is cracked (plastic). I need to know how to get it off so I can replace it with a rubber one.
  • 89 Answers
Are you sure thats the model number? Im having trouble finding it on my end???
Posted on Dec 17, 2007
  • 3 more comments
  • Brian Gillespie
    Brian Gillespie Dec 17, 2007
    If you open lid of washer there should be a label with model and serial number listed.... Still nothing with WJRR41700G
  • Brian Gillespie
    What hose is leaking. Drain hose or fill hose?
  • Brian Gillespie
    Ok, Its the drain hose... Give me a sec to put link on here...
  • Brian Gillespie
    Hang in there... This pic is to big to upload here and the link wont work... need a few more minutes
  • Brian Gillespie
Location of discharge hose on model GTWN5050MOWS
See step 3 of manual. Sears parts provides great customer service with parts and manuals
Hope this helps?
http://www.searspartsdirect.com/partsdirect/user-manuals/GTWN5050M0WS-GE-WASHER-manual
Jun 26, 2017 | GE Washing Machines
The washer is leaking from the bottom
Your center seal is going bad or you have a bad hose, leaking water pump, or a cracked tub but GE is notorious for there center tub seals to going bad I would recommend a qualified service technician come look at it to rule out which one it is if your centers tub seal is bad I would buy a new washer but sorry for the troubles.
Jan 22, 2011 | GE WBSE2090A Top Load Washer
I HAVE A GE TOPLOAD WASHER MODEL#WSKS2060T1WB AND ITS LEAKING WATER I CHECKED THE HOSES AND THERE IS NO LEAKS IN THEM I DID NOTICE UNDER THE MACHINGE THAT THERE IS A SMALL HOSE THAT'S CONNECTED TO THE SIDE...
Take tub out, liner is cracked above motor do to off center load. Install new liner but cut fin off above motor before installing to stop this problem.
Oct 05, 2017 | GE WBSR3140DW Top Load Washer
Agitator is slipping
I have a different model, but my agitator came off with brute force. I used 2 allen wrenches in the slots on the side of the agitator to get leverage and then yanked until it came off. The problem is your air bell coupler.
Jan 30, 2009 | GE WJRR4170E Top Load Washer
Loud & out of balance when washer is in spin cycle. Will do this reguardless of load size, Unit is level on floor. GE model # WJRR4170G. Purchased 3 wks ago
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
You have a warranty for free service that comes with a "new" machine.
Call service!
If your in the states here I will give you a good service company!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 26, 2008 | GE Washing Machines
My washer is leaking...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Apr 11, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Washing machine is leaking!
First check your supply hose for cracks or splits. If cracks are apparent the hose must be replaced. If none are apparent I would suggest taking apart the connection and checking the gasket or washer inside the fitting. If it has decayed or cracked this could be the culprit. Replace the gasket or washer with the same size. these are availiable at any hardware or home improvement store.
Jan 13, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Clothes washer leaking
First of all, check to make sure the drain hose is inserted properly in the drain pipe in your wall. Second, if that's not the problem, check to make sure the drain hoses inside the machine are tightly connected and not cracked. Tighten or replace as necessary.
Sep 25, 2007 | GE WCXR1070A
Washer leaking
There are several things that will leak under a GE washer. The the usual suspects are drain hose connections, or hoses that have cracks or holes. I would inspect the hoses first as this would be the easiest fix. The other thing that can causes problems is the wash tub seal on the bottom of the tub. If the spanner nut (under the agitator) comes loose, the seal will unseat and the tub will begin to drip (I've had this one happen to me). Another cause can be the wash tub itself (I've also experienced this one). Inspect the wash tub for cracks. The tub can develop stress cracks and begin to leak. Especially if this is a washer that was involved in a move. To access the inside of the machine, the front should come off by pushing under the front lip of the machine with a putty knife. There are metal clips that hold the front to the top. Look in the crack with a flashlight to locate them. Push in with a putty knife to release and the front should just come off. I hope this helps you.
Jul 05, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
229 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
