Question about Amana SXD524VW Side by Side Refrigerator
I own a amana side by side refrigerator...I have not hooked the water line up for 10 years...now I need to bring it back into service but notice the hook up appeared to have a treaded female junction more the size of a garden hose hook up. Is there a connector/adapter to hook up to the smaller hook up?
  • 334 Answers
Yes there is an adapter. If you purchase the ice maker line kit from Lowes or HD (the stainless steel braided line) they often come with the adapter.
I recommend the steel braided hose as they are flexible, and burst resistant. It will be a simple brass fitting with male end to go to the fridge, and the hose hooks up to the adapter
Posted on Sep 26, 2009
I have an Amana Side by Side Refrigerator with an icemaker and water dispenser. I don't have a water line to hook up to the refrigerator. Is there an on/off switch for the icemaker?
There should be a stop control near the icemaker where it collects ice in the tray. It should be an L-shaped lever. move it to the stop position.
Oct 02, 2012 | Amana Refrigerators
I recently purchased a used Amana Side By Side refrigerator that's a few years old. I've recently noticed water on the floor around the bottom of the refrigerator on the freezer side. I don't have the...
you need to remove the rear panel inside the freezer section,inside there will be the evaporator coil/core,below this is a drip pan/drain and they get frozen over,shut off the unit and put a bunch of towels there to catch water as it thaws,then use hot water to hasten thaw,then run a piece of wire down the drain hole,you will need to remove rear lower cover to see when wire comes out there,then after you get it starting to drain,clean out drain tube with hot water and vinegar
Mar 22, 2011 | Amana Refrigerators
No water coming from in-door dispenser
chances are you have a bad water valve,or the line for water is severed.....the valve your water line hooks 2 has 2 seperate solenoids,one for ice,one for water....the part is sold as an assembly
Mar 03, 2010 | Refrigerators
Amana SBD21VE No water to ice maker
your water line to the fridge is most likely leaking. You should turn it off right away. The line turn off is either behind the fridge or under sink. sometimes its in basement. The line is very easy to replace. You can get the plastic ones at home centers for under 5 bucks.
Jun 08, 2009 | Amana ASD2326HE Side by Side Refrigerator
Moisture on back black panel near the middle of the back of refrigerator
If this is equipped with an icemaker, check the water line for leaking also the ice maker water valve for leaking.
If you have a external condensate drain line on the rear,is it cracked and leaking?
May 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side
your thermostat in the frig is bad,you need to pull it and checkit with an omhs meter,let me know what you find-mike
Oct 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Water stopped dispensing, still makes ice
Yes Teri, you can.
What has most likely stopped the water is that it has frozen in the line coming into the back of the freezer section. You simply need to turn the box off and do a good cleaning. during the time that the box is off, the water line will have time to thaw. Put everything back together, turn the box back on and give it a try.
May 25, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
146 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
