Question about Samsung Digimax S630 Digital Camera
I broke the lcd screen what should i do - Samsung Digimax S630 Digital Camera
The screen to my 32" Proscan flat screen tv broke.
unless you have not mentioned your place its difficult. Better you find some importers,
otherwise contact the authorised service centre
Apr 09, 2011 | Proscan 32LB30QD 32 in. LCD TV
Hi, my son dropped my LZ2 camera and now it starts when I power it on, all menus and functions seems to be ok, but no image is displayed in the LCD. Any ideas what's going on?
The LDC screen most likely broke the screen did not crack by the actual underlying LCD screen broke the only option is to replace the screen or have it replaced at a local camera shop
Mar 05, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
Its about my lg xenon cell phone . i broke my lcd
well with the voicemail,go to more settings, call fowarding then all voice calls. it will tell u what ure number sould be if you reset it =)
Jan 21, 2010 | LG Xenon GR500 Cell Phone
MY SCREEN \BROKE ON THE INSIDE OF MY DIGITAL
Unfortunately repairing a damaged LCD screen is not possible. Your best option is to purchase a new LCD screen for that model and see about having it installed or installing it yourself.
Jan 19, 2010 | GE A730 Digital Camera
I have kdl-40v4150 this tv, lcd broke and i wanna
Not possible,tv compannies never sell LCD screen by it self or will cost the same as the new tv.Only buy it on Ebay.com for use part or broken tv with good LCD.
Nov 14, 2009 | Sony KP-53HS10 TV
Screen broke
Yeah i have replaced a lcd screen before but you need to get what model screen you need...
http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&dlc=en&cc=ca&lang=en&product=3340198
here is the contact page you need to send them an email, just ask them what the model of the lcd screen is and swap them out.
Jun 22, 2009 | HP Pavilion dv9205us Notebook
Dynex dx-lcd32-09 lcd screen broke
If the LCD screen is broken, you should consider selling your set for parts. The cost of a LCD replacement is not cost effective. Examine the screen to verify.
If the LCD screen is good you can check to see if the "image" is being "sent" to the screen.
1) Take a bright flashlight and place it against the screen with the set on.
2) If you see an image around the edge of the flashlight the problem is in the inverter/CCFT or the power to it.
3) If you do not see an image the problem is probably in the LCD Controller (TCON) or its connections.
Jan 31, 2009 | RCA L42WD22 42 in. LCD Television
Broke lcd
Start by removing the screws for the screen bezel, the plastic cover around the screen, then the bezel snaps off. Be careful not to break it, they break very easily. The screws are hidden/located under stick tabs or the small rubber bumpers. Once you have the bezel off you will see the screws holding the screen, and the screen and inverter connectors. The rest is self explanatory, the screen goes back in the same as it came out. HP's support site has many service manuals and illustrated instructions for many of their machines. So, keep this in mind if you get stuck.
Aug 12, 2008 | Computers & Internet
LCd screen replacement for pilot insignia mp3
You can with a good soldering iron, but you needs a good screen. Get one that doesn't come on and switch the screens. Its hard because they solder the lcd cable to the mainboard, but it can be done.
Feb 25, 2008 | Audio Players & Recorders
ALEJANDRO
If the screen is broke as in "cracked", it's typically not practical to replace that part.
Oct 23, 2007 | Hyundai ImageQuest HQL260WR 26 in....
Samsung Digimax S630 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
