Question about Rockford Fosgate Punch 600a4 Car Audio Amplifier
Fosgate 600a4 amp, no sound LED stays on
I have a Rockford Fosgate Punch 600a4 amp that is about 10 years old. It has lasted forever, but I noticed for the past few years, it would overheat and shut off, but turn back on when it cooled. Recently, I noticed that the amp was not as loud as it was before. Then the sound shut off completely, but the remote LED light stays on. I believe this amp has been serviced before, but I don't know what is wrong with it. If it's part of the circuitry, I can repair it if I knew what it was and where to buy it.
  • Perry Babin May 11, 2010
    It's uncommon for Rockford amps to fail and have the power LED lit. Are you sure the amp is defective? Have you checked the speakers?
5 Suggested Answers
SOURCE: Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
Posted on Sep 02, 2007
  • 631 Answers
SOURCE: rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Posted on Nov 05, 2008
  • 182 Answers
SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
replace the inputs on ur amp
Posted on Jun 29, 2009
Professor_V
  • 92 Answers
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Posted on Jan 06, 2010
Can a rockford fosgate 500a2 run 1 ohm stable
yes, if you add a 1 ohm resistor to the negative terminal of speaker.
May 08, 2014 | Rockford Fosgate Punch 500a2 Car Audio...
How do u bridge the rockford fosgate p325.1?
Hello... sorry you are having a problem. If you are running the 325.1, that amplifier is strictly a mono-block amplifier (1 channel) so it is not possible to bridge it. There are 2 speaker connections on the amp but both positives and negatives are connected on the circuit board in the amp. Hope this helps. Good luck with your venture.
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Rockford Fosgate Punch P325.1 Car Audio...
Problem(s) Description(s): Initially intermittent output with good audio quality on all four speakers/channels,( five minutes of output then maybe two minutes of silence) then no output at all on all four...
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 16, 2010 | Rockford Fosgate Punch 600a4 Car Audio...
I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
LINK
Sep 25, 2009 | Rockford Fosgate Punch 150a2 Car Audio...
I get a better sound with my 250.2 than with my 500a2
Rockford Fosgate was bought out over 10 years ago. the amps you have are from that era. Its probable that the 250.2 was made before the change over, and is just a better quality amp. the a series amplifiers were some of the first produced by the "new" Rockford Fosgate, and they sucked, along with most of their products since.
Aug 07, 2009 | Rockford Fosgate Punch 500a2 Car Audio...
I HAVE A PUNCH 600a4 IT WORKS AND BANG BUT IT GETS HOT IN 5 MIN
make sure it is grounding right and dont use it on its peak power
Jun 30, 2009 | Rockford Fosgate Punch 600a4 Car Audio...
Rockford Fosgate Punch 301X not runing
You should verify some other way (with a multimeter or another amp/device) that your 12V is working at the amp. Then to troubleshoot the Remote wire, take a short lead of scrap wire and run it from the 12V power input of the amp over to the Remote input like a jumper. If the amp still doesn't power up, then look for and check the fuse on the amp. If there's good power at the amp, the remote input has good power, and the amp doesn't turn on, and the fuse isn't blown, then the amp is probably toast. Good luck!
Jun 17, 2009 | Rockford Fosgate Punch 301X Car Audio...
Amp gets very hot in as little as 5-10 min.
Whats the omh load and how old is amp??? The old Rf amps always got hot that how they worked.... No ventilation????
Nov 05, 2008 | Rockford Fosgate Punch 700S Car Audio...
Rockford fosgate punch 700s gets very hot
Nov 03, 2008 | Rockford Fosgate Punch 700S Car Audio...
Rockford Fosgate Punch 600a4 Car Audio Amplifier Logo
202 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
