Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
I have the sony wega 60 lcd tv, it turns on ok then shuts off
I have the sony wega 60 lcd tv. it turns on fine but after about 20 seconds i lose sound and picture. the green light stays on in the front but the picture and sound will come back on every 20 seconds or so then go right back off. can any1 help please???is this a bad bulb? or possibly a bad mother board like i have been told?
  • moonweezle9 Sep 27, 2009
    it is supposed to have a red light on the front that is supposed to indicate when the lamp is bad but it doesnt come on at all.
    Genius:
  • 1,112 Answers
How long have you had the set? If its been at least two years then its time for a new lamp.
Thanks
you can email me at Delhielectronics@live.com
if you need futher assistance. I believe your lamp is faulty...
Posted on Sep 27, 2009
  • Lavell Turner
    Lavell Turner Sep 27, 2009
    Ok, maybe there is but you have to realize that if you turn on your television at the start of the day and the unit plays and you get a pic, at this point the television has determined that your lamp is ok, Sony lamps indicators do not light if this happens as it thinks the system is operating normally.
    THIS IS ONLY IF YOU CAN GET A PIC.
    So here is a way to verify if the lamp is faulty.
    1. Starting with the television off
    2. Push the Display button
    3. The number 5 channel button
    4. The Volume up Button
    5. The power button, you have to press these buttons in sequence within 5 seconds of pushing Display button.
    A diagnostic menu should appear, listing the various checks it makes during what is called the post(Power On Self Test). Look under the options Lamp Driver if there is a number to the right of these listings, this indicates the number of times the unit encounter these errors. Example if Lamp door has recorded a one, this means the door to the lamp has been removed once etc....
    Now hit the number 8 key and press enter on remote and turn off power. This will reset all recorded errors to Zero.
    Now turn the television on normally. Wait until it happens again and do the above procedure again and note what it recorded. If it records a 1 again under lamp driver, first replace your lamp if replacing your lamp does not solve this then the Ballast (Lamp driver) which is used to light the lamp is faulty. Keep in mind that a recorded error on lamp driver could also mean a bad lamp. You have to start some where to solve your problem. Start with the lamp especially if its been a year or so since you brought the television, forget the red lamp light for now. Heck that light could be out too. Take the lamp out and inspect it, the reflector in the lamp should be very shiny, if it looks cloudy and worn replace it. Also look at the base of the bulb itself in the center of the lamp it should not be buldging like it is swelling if so replace it...Call me if you need more Assistance...Thank You.
    Lavell: Delhielectronics@live.com
    Phone: 702-418-1389
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a sony grand Wega KDF-kdf50e2000 and when you turn the TV on it will work fine for 40 seconds and then go off with the green power/standby indicator flashing. After 40 seconds the TV will come back...
you have a ballast issue this is a common failure for LCD rear projection read this link and you will see why I think this
http://www.fixya.com/support/r3556856-how_to_know_if_it_is_the_lamp_or_ballast
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 28, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a 60' sony wega r60xbr1 i just had a new light engine installed last night the tv was never turned on afterwards . I turned it on the screen come on shut off imediatly the red led flashes 4 times...
LOOK IF YOURS IS A SONY I had a sony grand wega 60 inch with the same problem as many tv turns on shuts off the red led FLASHED 4 TIMES. it is a heating issue if one of the three fans inside are not turning when the tv is on even on the first few seconds of turning it on the tv will send a fault code of four flashes . Then the tv shuts off so it wont burn its self up or damage the optical block. all with this same problem of 4 flashes take a flashlite and make sure your fans are turning if not that is your 4 flash problem. I hope this helps someone and if it does i have done my job .
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have a sony wega kdf e55a20 that keep on shutting on and off
Lamp is weak and TV needs new lamp.
Please buy original Sony Lamp for better performance of TV.
Jan 19, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand WEGA KF60WE610 60...
The first place to start is to change the lamp
May 11, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
588 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
