Question about NRS Paslode T250-f16,s200-s16 Nailer & Stapler O`ring Parts
T250S-F16 16 Gauge Straight Finish Air Nailer i have an air leak out of the front of the gun where the driver comes out and makes contact with the nail head (the hole tri-shapped hole) It only leaks after the gun has fired and i continue to hold the trigger all the way down. I replaced all gaskets and o-rings including the piston driver o-ring which i thought would solve my problem, but it is still leaking. any suggestions?
  • David Ford
    David Ford May 11, 2010
    what about the cylinder seal? is it pitted or possibly cracked? also what was the bumper condition? if you release the trigger does the leak stop Let me know and I will try and help
    President:
  • NRS Master
  • 1,388 Answers
Air leaks from the bottom of nailers are due to leaking oring /s that seal cylinder to body of gun and/or leaking thru seal at top of cylinder where headvalve seats. Remove head and examine sealing surfaces of headvalve and top of cylinder. Must be smooth, then pull out cylinder and check oring/s that contact body of gun. Remove any fine scratches on inner body with fine paper (400 grit). Lube with silicone paste. Good Luck!
Posted on Oct 18, 2009
Paslode im250 works fine but makes loud gun like bang noise, can I reduce bang sound.
Take a look at the internals and see if there is an air leak or muffler problem:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/paslode/IM250_A/
Jan 20, 2013 | RTO Paslode 902000 IM250 Ii Cordless 16...
Gun leaks
No it is not. It should not leak at all. Where is it leaking air from? The 3 obvious places are the exhaust at the top of the head, the nose where the driver comes down, and the trigger valve.
Jul 29, 2012 | Campbell Hausfeld 2-in 18 Gauge Brad...
Air leak out of driver unit
In most nail guns the piston o-ring is the problem. Inspect the o-ring for any signs of damage and in some cases the o-ring has a manufacturer defect.
Mar 23, 2012 | Stanley Bostitch SB1664FN 16 Gauge...
How do I load the 2 1/2 inches nails to my 16 ga porter cable finish nailer? How do I put the oil and what part of the gun?
You need to open the nail magazine and you just load one strip of nails at a time, then close the magazine. It will have a spring putting pressure on the nails, so it will have resistance on it and it will increase as you close it.
The oil gets dripped in the air hose connection on the gun before you connect the air. Make sure that this gun actually takes oil, some newer guns are oilless.
Hope this helps,Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 10, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
My gun is leaking air ... a have 2 finish nailers and are leaking air , please can u tell me where can send those to fix?? i'm in north south carolina my sip code is 29536
The closest loction to you is in Charlotte:
DELTA | PORTER-CABLE/DEWALT FACTORY SERVICE #042
3557-B WILKINSON BOULEVARD
CHARLOTTE, NC 28208
US
704-392-0245
Oct 01, 2009 | Porter Cable 2 - 1/2" 15 - Gauge Angle...
Stanley finsish nailer and air is leaking through the trigger as.
If the air is coming out the trigger it must be replaced. Depending on the model of gun you will have to replace the trigger assembly or various o-Rings. Find a Bostitch dealer in your area and they will supply the parts you require.
Jul 14, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
We have a Bostitch nailer that leak out of the end
there are o rings inside the nail gun, remove the allen head screws and get replacements.
Apr 10, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
NRS Paslode T250-f16,s200-s16 Nailer & Stapler O`ring Parts Logo
260 people viewed this question
Top NRS Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
yoopertech
Are you a NRS Air Tool and Compressor Expert? Answer questions, earn points and help others
