Unable to load drivers for diablotek 2.0 USB DVDROM
MODEL: EXDVALB
Get ''error: copy file''
I tried 2 different laptops, same problem. I'm running Vista
Home Basic. I can't find a download site for the driver.
SOURCE: DVDRW DVR -K17B all of a sudden can't load driver
go to device manager and try to download new drivers, if that doesnt solve the problem uninstall the device and reboot.
let me know if that doesnt solve it.
SOURCE: Mad Dog USB DVD-RW not recognized
Bump, i have the same problem any one else with have another solution?
SOURCE: HL-DT-ST DVD-RW GWA-4082N driver needed
Try the link below, you will satify with the solution because my laptop used to have this problem. Good luck
http://www.fixya.com/support/r380953-missing_dvd_cd_rom_drive_letter
SOURCE: Toshiba Satellite L3550-S7812 - Following
Ok! I'm not an expert, but I took advantage of my Toshiba warranty and got some tech support. Fortunately, I remember what they told me to do and I wish to help. :D I have Windows Vista, so if something isn't quite the same, ask and I can probably clarify it for XP.
We will be editing the registry, so please back up your computer/set a system restore point.
First, make sure all programs and windows are closed, then open the start menu and type into the "command" into the start search field (for xp users, go to run, then type in "cmd") and press enter. This will open up the command prompt window. It's a black window.
Now, in the black box, type in "regedit" and press enter. This will open up the registry editor. We will be deleting two values from the registry in order to make the computer properly detect the DVD drive.
Once you have the registry editor open, you will have to open a series of folders to access the particular registry values that need to be deleted. It will be displayed like this:
Folder>Sub Folder>Sub Sub Folder
Please open the following folders in the registry editor in the following order:
HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > Class
From here, you need to select the folder which is ninth from the top in the Class folder. The name of this folder is {4D36E966-E325-11CE-BFC1-08002BE10318
In this folder with an extraordinarily long name of jibberish, you will find two files entitled "LowerFilters" and "UpperFilters," respectively. Click on LowerFilters to select it then either right click and select the delete option or simply press the delete key on your keyboard, then confirm that you would like to delete it. Click UpperFilters to select it then repeat the process followed for LowerFilters.
Lastly, close all windows and restart your computer.
Your DVD-RW drive should work now. To test it, put in any CD/DVD/whatever.
I hope this helps and if it doesn't, then I apologize. I wish I could help more, but I'm just repeating the process Toshiba tech support went over with me.
Have a good one. :)
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
cd/dvd then plug them back this should activate the found new hardware
wizard or you might
have to uninstall then restart your computer then reinstall your DVD/CD then
reinstall the driver for this device
a motherboard disk the drivers could be on it click start control panel
or
http://download.cnet.com/sun-cd-dvd-burner/3000-2646_4-10308060.html
Sun CD/DVD
Burner can back up data on CDs and DVDs, store large media files, and compile
music CDs. It can burn and save whole ISO files, as well as create multisession
CDs and erase rewritable CDs. Sun CD/DVD Burner supports almost all kinds of
driver types including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM
(SCSI, IDE, EIDE, and USB). The program also supports the ability to drag and
drop. Version 3.10 may include unspecified updates, enhancements, and bug
fixes.
What
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
