Question about HP Officejet 5610 All-In-One InkJet Printer
How do you remove the ink toner cartridge - HP Officejet 5610 All-In-One InkJet Printer
  • 58 Answers
Below link will help in that
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00442122&cc=us&lc=en&dlc=en&product=441125
check out the video in the link.
really help ful
Posted on Sep 27, 2009
The print is not showing and the cartridge is new
Ink cartridges and toner cartridge have film strip that must be removed before they can dispense ink or toner. Find and remove the strip, and try again.
May 01, 2016 | Office Equipment & Supplies
DX-3443 ink is not supply to drum
You copier does not use ink, but toner. And because the "ink" detector is on, it could be the toner cartridge is empty.
Try to remove the toner cartridge and shake it firmly. than replace it. This could help for a few copies, but you must order new toner, if the sheets of paper keep coming up blank.
Jun 10, 2014 | Ricoh Aficio 250 Copier
Out of toner
Make sure that the toner ink cartridge is a genuine Lexmark toner cartridge. Try removing the toner cartridge and then shake the toner sideways. Re-seat the toner cartridges and check if the error persists. If it does, please contact our Technical Support Hotline.
Dec 03, 2012 | Lexmark T520/522 BLACK PREBATE TONER
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
How to refill ink in it
The printer doesn't use ink, it uses toner, a black powder. The toner is then pushed onto the page using magnetic force and fused to the paper using a laser. Which replaces the traditional "ink injection" method.
The toner cartridge is a black unit that pulls out located behind the top access panel in the front. This unit contains a glass drum and behind it a well of toner powder. Usually you have to replace the entire unit.
There are toner cartridges with plastic caps which can be removed and then refilled with the powder. However, this powder is messy, difficult to manage, and eventually the drum will become scratched and worn since it is not really designed for prolonged use. So I recommend just replacing it.
While the toner cartridge will run more than ink. The frequency with which you have to replace it is significantly less. So while ink can run you as much as $0.25 a page when you factor in the wear and tear on the printer. Laser printers are more along the lines of $0.04 a page.
If you replace the toner, read the directions carefully and be sure to remove the plastic shipping strip from the side of the cartridge. This strip is used to hold the toner in the cartridge while it ships and will keep it from working properly.
May 12, 2010 | Canon LASER SHOT LBP-2900 Printer
How do I change the ink cartridge?
Hello.
This printer is a laser jet printer - so you will be changing the multiple toner cartridges, not ink cartridges.
Page 56 starts the steps on how to replace the toner cartridges.
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2300dl/eg_user.pdf
The front of the printer opens to the right and exposes the toner cartridges for removal.
May 04, 2010 | Konica Minolta magicolor 2300DL Laser...
What to do when toner is low
Remove the toner cartridge.
Gently "roll" it from side-to-side, to evenly distribute the toner. Do not "shake" it.
Eventually, you'll either need to buy a new toner-cartridge (either from Dell or via eBay) or find a store that refills ink-jet and ink-toner cartridges.
Apr 16, 2010 | Dell 3000cn Laser Printer
Cannot take out the ink cartridge out of the epson aculaser C1100
You must follow these steps to replace the toner cartridges:
  1. Turn the printer on.
    getimage.ashx?id=912&w=
  2. Open Cover A.
    getimage.ashx?id=913&w=
  3. Push up the right lever to unlock the toner cartridge.
    getimage.ashx?id=914&w=
  4. Remove the toner cartridge from the printer.
    getimage.ashx?id=915&w=
  5. Take the new toner cartridge out of its package and gently shake the toner cartridge as shown below.
    getimage.ashx?id=916&w=
  6. Hold the tag and gently pull the toner seal upward and remove it.
    getimage.ashx?id=917&w=
  7. Insert the cartridge all the way until it stops securely with the arrow mark on the top of the toner cartridge facing toward cover A.
    getimage.ashx?id=918&w=
    TIP: Hold the cartridge in the middle as shown in the picture. Push it gently all the way through the rails. Make sure both sides of the cartridge are inserted at the same time. Keeping some pressure in the middle of cartridge until you hear a ‘click’.
  8. Push down the right lever to lock the toner cartridge.
    getimage.ashx?id=919&w=
  9. Close Cover A
Apr 02, 2009 | Epson Aculaser C1100 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
