Question about Hitachi 50FX48B 50" Rear Projection Television
Picture and sound went out at same time.
The picture and sound went out at the same time.
    President:
  • 632 Answers
The projection lamp is gone and needs replacement. The lamp typically lasts about 8,000 hours on high end models and 1,000-2000 hours on cheaper models.LED technology based lamps lasts for about 20,000 hours. Operating the TV in a warm environment without enough ventilation or at high elevations reduces the lamp life. Setting the color or contrast to a lower level increases the lamp life.
Here's how to replace the lamp:
  1. Turn your TV off. Let it sit there for about 5 minutes to let the cooling fan help cool the lamp.
  2. Unplug your TV from the power let it sit about another 30 minutes.
  3. Usually the lamp has a cover that you will need to unscrew. Most manufactures use a Philips head screw for holding the cover shut. Unscrew the lamp cover.
  4. Unpack the replacement lamp. Be careful not to tough the glass, as oil from your fingers can damage the lamp's surface.
  5. Pull the lamp out. Most lamps have a plastic tab or hoop on the handle that you can use to pull it out. Follow the owners manual for specific instructions on how to pull the lamp out. Make sure you do not touch the surrounding lamp housing if you just turned off the TV. It can burn you if it is hot.
  6. After the lamp has cooled, place it into the empty box of the replacement lamp. Never put the used lamp into a plastic bag.
  7. Using the guiding post also called "gutters" by some manufactures slide the lamp replacement lamp in pushing it until you hear a firm click.
  8. Screw the lamp cover back in.
Posted on Sep 26, 2009
Have Hitachi LE42LS256, SN LE42LS256 SK2J000667 power surges. went off,came back on,could hear sound no picture, then the sound went out.blue on light on set is on, no sound or picture.
The chipset in the TV could be failing, I would say replace the bulb for the picture, however if you are getting no sound its safe to say the motherboard is probably toast. Projection TVs, and HD TVs in general produce a lot of internal heat. Over time it will damage the circuit boards, maybe time for a new TV!
Dec 04, 2016 | Hitachi Televison & Video
Tv went crack while watching. Picture and sound went out & red light flashing.Waited a min,turned off and back ok with picture and sound returning concerned if we should continue using or not?
As long as you can see and here the picture with no problems you should be fine. The tv's put it heat which make things expand and contract. Sometimes things creek and crack. I've had two tv's that do that. Don't hesitate to keep a fire extinguisher handy though along with some alarms.(houses should have these at all times anyways)
Mar 07, 2015 | Televison & Video
Why would a Mitsubishi WD-65735 Television turn on and have sound but no picture?
have you pulled the lamp out & checked it. It is possible you have gotten poor quality lamp. It is critical on a mitsubishi to get the proper lamp.
Lamp-Cartridge 915B403001
http://www.shopjimmy.com/mitsubishi-915b403001-dlp-replacement-lamp.htm
May 08, 2014 | Televison & Video
Pop sound tv went black, went off then back on had sound but no picture, I turned it off and it turned its self back on at this time no picture and no sound. I unplugged tv and when I plugged it back in it...
An electrolytic capacitor has gone bad in you high voltage section of your TV or the high voltage oscilater has gone failed please have tech check and replace
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
TV went out over time. Sound immediately, but no picture. Loud POP noise when i changed channel. After a while it would "warm up" and would work fine. now doesnt show picture at all. In monitor mode...
Check the power supply first for bac capacitors (learn more here about bad capacitors: http://en.wikipedia.org/wiki/Capacitor_plague)
I had replaced capacitors in my, hopefully it did not cause damages to other circuits such as backlight inverter board.
Nov 02, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Sound but no picture
The first thing to check is the connections to your source. They can easily become loose and/or corroded over time.
Feb 25, 2009 | GE 46GW945 46" Rear Projection Television
Picture went out but still have sound?
possibly the vertical output IC is defective. I would try resoldering it first as most times that will correct the problem.
Jun 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
170 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
