Question about Sony PlayStation Portable (PSP) Console
I WANT TO CONNECT MY PSP TO INTERNET AND IT SAY ERROR IP ADDRESS NOT FOUND.WHAT SHOULD I DO?
  • 3 Answers
When you try to connect your unit are you on a wi-fi spot ? and if you dont then you that message would appear everytime you connect.
Posted on Sep 26, 2009
It wont go on to the internet because there is a error and the code is 80410410
This might not work because i don't know what your exact setup and situation is. but i would get on your pc, make sure its connected to your home network, and open the command prompt. Type "ipconfig" and hit enter. now, turn on your psp, go to your network settings, and copy the data you see there into the appropriate areas on your psp. just don't copy the ip address, because that address is specifically assigned to your computer. lets say my network ip address 192.168.1.1, and my computer has an ip address of 192.168.1.2. If i want to manually assign an address to my psp, i would chooes something like 192.168.1.55, because that address isn't being used.
Feb 24, 2011 | Sony PlayStation Portable (PSP) Console
I want to connect internet on my psp through a wireless access point but iam constantly recieving dns errors , what settings should be made on my psp and my access point? to solve the problem???
  1. Connect your router
  2. Open a brower window on your computer, preferably Internet explorer.
  3. Enter the IP address of the router (Ex: 192.168.1.1)
  4. Upon entering the IP address of the router in the browser it should direct you to your router box. If this does not happen then most likely your router box has been configured to a different IP address. To get this IP number run the set-up program.
  5. Now in the routher settings navigate within your router's settings dialog and locate "Wirless Settings"
  6. Check if you are assigned a SSID
  7. Check your region
  8. You should be on Channel 11. Sometimes the channel could different, in such situations make sure you are on the same channel.
  9. Check if "Allow Broadcast of Name (SSID)" is enabled
  10. Check if "Enable Wireless access point" is enabled
  11. Set authentication as "Open system". You will find this option under "Security Encryption (WEP)"
  12. Set strength of encryption as "Disabled"
  13. Now click on "Wireless Card Access List". You may need to provide your password again.
  14. Make sure "Turn on Access control" option is turned off "Disabled"
  15. You should now see your PSP listed. No, you dont see then on your psp, go to "system settings" and then to "system information". You will see MAC address, now make a note of this MAC address.
  16. Now in "Wireless Card Access List" select "Add". If you are not able to do this then enter the PSP's MAC address and click "Finish/Apply" when done.
  17. In WAN settings, verify that "Connect Automatically as required" is enabled
  18. In "LAN TCP/IP Settings" make note of all of the information included. You may need this later. You may not, but it's a good idea to take note of it now.
  19. Under "Router Status" make note of all the relevant information included here as well. You may or may not need it.
or click to view manuals.playstation.net
Aug 24, 2010 | Computers & Internet
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
What is ip address
to fix go on ip chiken.com it will give you your ip
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
Psp connection to internet
You probably have your wi-fi under secured network.
Oct 02, 2008 | Video Game Consoles & Games
Psp internet doesn't work.
Try power cycling (turning everything off for about a minute) and connecting again.
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
Connection error
Error code : (80410418)
- The PSP is unable to obtain IP address.
+ Check your router's firewall if its blocking the PSP.
+ Turn off the proxy in the PSP.
Check those and tell me whether still the problem exists
Jul 11, 2008 | Sony PlayStation Portable (PSP) Console
Psp error
do your memory and sound work,moe3 and rosspeters?
if not,its a problem with the memory/sound/wifi circuit board.
if they work,it may be your antenna that is malfunctioning.
you probably will need to replace those,so be prepared to spend around $20.
Jul 09, 2008 | Sony PlayStation Portable (PSP) Console
Dns error # 80710102 ip address ok but internet connection fails
Contact your network admin or Your ISP (Internet Service Provider)
-Rel
May 28, 2008 | Sony PlayStation Portable (PSP) Slim...
Cannot Use Wireless LAN
the problem is common, you need to set up the psp manually and not let it obtain an ip address automatically. the easiest way is to find either your router ip address or your pc's ip address e.g if your routers ip address is 192.168.2.1, then your pc's allocated address will be 192.168.2.2, so set your psp address to 192.168.2.3. you will also need to set the gateway address, this is your routers ip address(the one you type in your browser to get into the routers settings).e.g 192.168.2.1. the DNS setting will be 255.255.255.0, all other address settings required will be the routers ip address eg 192.168.2.1.
Aug 02, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
