Question about Bosch Washing Machines
I have a Bosch washing machine (Classixx) which has been problem-free since I bought it just 6 years ago. Today I tried to clean the drain pump to check for debris / fluff. I've never done this before, and followed manual instructions, up to 'Completely remove the pump cap'. No matter what I do, I just can't get it to shift - I don't even know what position the cap should be in in order to do this. I would really appreciate some help. Many thanks, Dorrie
  • 725 Answers
Look for a small hole in the cover with a wire you can press the release tab.. remove bosch pump cover 1) insert wire in small hole in cover 2) while pressing in on wire twist cover 3) remove cover 4) with the handles of plires twist off pump cover Let me know if it helps or I can go deeper into it.
Posted on Sep 26, 2009
  • Franklin Ouchida
    Franklin Ouchida Sep 26, 2009
    to remove bosch pump cover
    3) remove cover
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
My bosch classixx 1400 express washing machine drain pump sometimes does'ent work
bosch classixx 1400 express washing machine drain pump This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 13, 2013 | Bosch Washing Machines
MACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
May 31, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
May 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Got the Bosch Classixx 6 1400 Expresswashing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks!
May 14, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Got the Bosch Classixx 6 Express 1400 washing machine cant
Feb 22, 2010 | Bosch Classixx WFO 2466 Front Load Washer
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Feb 23, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Washing Machines Logo
404 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
