Question about Sewing Machines
How to thread the bobbin
How do I thread the bobbin on my singer 6235 sewing machine?
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
Posted on Oct 26, 2008
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
Posted on Jan 23, 2010
SOURCE: Looking for a free download of Singer Sewing Machine 6235
if you still haven't found one, reply to this thread. I have one as a PDF that I just bought for $5 that I'd be willing to share (this goes for anyone who finds this post, too)
Posted on Feb 26, 2010
  • 1116 Answers
SOURCE: I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
Posted on Mar 06, 2010
0 characters
1 Points
On my Singer 6235 sewing machine, needle will not pick up bobbin thread. Any suggestions to fix the problem?
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Mar 01, 2016 | Singer Sewing Machines
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
Cant remember how to load my bobbin on my singer 6235 machine
Go to and download a free manual for your machine. Look under support and enter 6235. It is nice because you can save it plus enlarge the diagrams in the manual. Nice to have a manual on your computer that you cannot misplace, LOL. We all get forgetful, I know I do.
Oct 29, 2010 | SINGER 7470 Sewing Machine
Singer 5430C bobbins thread always loopy
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Feb 15, 2010 | Singer 5050 Mechanical Sewing Machine
Apr 24, 2009 | Singer Sewing Machines
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Threading bobbin for singer 8734
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Sewing Machines Logo
140 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Are you a Sewing Machine Expert? Answer questions, earn points and help others
