Question about Dryers
Squeals when drum turns
The dryer squeals when the drum turns
    President:
  • 3,085 Answers
Replace the drum belt and oil the tensioner
Posted on Sep 26, 2009
My dryer won't spin and is squeeling
It sounds like either the belt is loose or the drum is frozen. Try the following links to see if they help.
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
This will help if you have never repaired a dryer.
User Manual Downloads
Feb 05, 2016 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
Squealing dryer
Sounds like the drum bearings are going bad, or at the very least need lubrication. thats what your problem is.
Jan 25, 2008 | Estate TGDS740JQ Gas Dryer
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
When its drying it has a high pitch squeal.
Many driers have a belt drive drum. This might squeal if is slipping. Check the drum turns easily and the belt is adjusted correctly.
Jun 29, 2011 | Fisher and Paykel SmartLoad DG62T27G Dryer
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Dryers
Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
Jun 11, 2009 | Hotpoint Dryers
Squealing dryer
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Feb 21, 2009 | Frigidaire GLER341A Electric Dryer
When I turn my may tag dryer on it squeals. We tried lubricating the mechanics then the drum stops turning. We then degreased it, hand spun the drum and it resumed working.
Squeals will usually come from the rollers that hold the drum or the one that puts tension on the belt. Also, check the front of the drum where it meets the front of the dryer. There may be some teflon pads worn out. The rollers can be lubricated for a short term fix but should be replaced.
Dec 16, 2008 | Dryers
Dryers Logo
75 people viewed this question
Top Dryers Experts
