Question about Genius SW-HF5.1 5000 Computer Speakers
Drum in the subw.
I have a problem with my system (GENIUS SW-HF5.1 5000)
When I start the system (by remote cont.) after 2-3 sec he starts to make a strange noise like a drum,about 2 beats/sec. and he wont stop,but it can be heard only from subwoofer,the other speacers stays mute...
When I start a music or something I cannot hear also nothing from it...
I wonder if you can help me...
Btw. I try to disconnect from power suply,but it wont solve the problem..
Thank you for your answer...
Alex
    Top Expert:
  • Genius Master
  • 80,407 Answers
The speaker amp has failed, best course is to just replace the system.
Posted on May 19, 2017
2 Suggested Answers
SOURCE: Genius SW-5.1 computer speakers, only 2 speakers, work!
i have the same problem and it is because my pc only have one plug for the speaker and it needs 3 so i did some research and i found this on amazon.com it seams that 17% of the customers buy it with the speakers it's Logitech 5.1 Game Console Adapter Convert Rca Plugs To A Single 1/8 and its only $4.99 so this is it :)
Posted on Apr 25, 2010
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 14, 2014 | Minolta Office Equipment & Supplies
What means of po cont on canon np 6650?
PO cont means Drum Potential Control,
If po cont set to 0, it means scanner system adjust the document darkness automatically but you may face many printing problems such like auomaically over dark, over light, heizzy, dull, etc etc.
if you want to trouble free printing, please set PO-Cont to 1
Aug 11, 2011 | Canon NP 6650II Copier
I have a sistem genius 5.1...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 01, 2011 | Genius Soundmaker Value 5.1
12RES GEN.NAT.GAS FAILS TO START BY STRT BTTN AND TRNSFR SW
If the succession is 3-5 sec crank - 3-10 sec pause, it is OK, but the cranking is not successful (the reason should be investigated).
If the succession is more rapid 1 - 2 sec you may have bad PCB control.
Jun 03, 2010 | Kohler 12 kW Emergency Power System -...
Woffer Problem GENIUS SW-HF 5.1 5005
Don't do anything to your speaker, it may ruin the warranty for it. The best thing to do is take your new speaker back to the store where you had just bought it. They may replace the speaker if found a factory defect on it. Contact first the store where you bought it.
I hope this could help you..:-) Thanks..
Dec 26, 2009 | Genius SW-HF5.1 5000 Computer Speakers
Bulldog Deluxe 500, remote not starting the the vehicle
Remove the battery in your remote for 15 sec, then put back in, start your car with your key, wait 15 sec, while the car is running press the * star button 2 times, it should beep , if not try it again, if still nothing post me back and we can go from there
Feb 22, 2009 | DLX 500 Remote Car Starter
Regional code for dvd player
Reagrding unlock of samsun ht-x715.
Found this
http://www.amazon.com/review/R2FMHKVOZYF6HX/ref=cm_cd_NOREF?%5Fencoding=UTF8&cdPage=&cdERR=noPurchase#CustomerDiscussionsPost
Worked for me with a small change
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. press the 'Repeat' on the remote for 10 sec'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
Dec 30, 2008 | Samsung HT-X715T Theater System
Griffin evolve remote not functioning
how did you take off the back to put in new batteries... try syncing your speakers by holding the 2 volume buttons on the base at the same time for about 2 secs.... the light will start to blink and you just click any button on your remote. If that doesnt work then its firmware
Dec 28, 2008 | Griffin Technology Evolve Wireless Sound...
Remote car starter problem.....?
need to know what car and model of unit you have . it is a sec. or ignition wire problem
Dec 23, 2008 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
Open Questions:
Genius SW-HF5.1 5000 Computer Speakers Logo
65 people viewed this question
Top Genius Audio Players & Recorders Experts
ptpumpman
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Genius Audio Player and Recorder Expert? Answer questions, earn points and help others
