Question about Coldtech 16 cu. ft. / 453 liter Commercial Freezer U2CRR-16S
We have a jimex cold tech model j45rf-40b and it is displaying a DF mode. Any idea wahat this is?
  • 358 Answers
Most of the freezers DF mode means that is in the defrost cycle.
Posted on Sep 27, 2009
Need to know how to higher the temperature on a DF 830 double door deep freezer as its too cold
What are you saying is "too cold?" Normal freezer temp is 0 degrees F, how did you measure the temp?
Jun 05, 2016 | Freezers
Emerson model cf450
Without getting into too much detail it sounds like ice build up may need defrost its do able but I'd recommend a tech it should be about 120 to 200$ to have jib done right
Dec 07, 2013 | Freezers
Commercial freezer stops cooling and goes into delay start mode.
unfortunatly the company has gon out of buisnees and parts available
are kind of hit and miss. As a profesional technician it really frustrating.
I would definitly look at the control side of it. some it could be the relay or digital controller. Good luck hunting the parts down. There are some online parts dealers that still carry some parts. Have your model number
and serial number readily available when ordering.
Jan 17, 2013 | Coldtech 21 cu. ft. / 595 liter Commercial...
I have a up right hoshizaki model fh1-AAC unit will not come out of defrost
These machines do not work like you think. The display will show the defrost mode even when in the freeze cycle. After a defrost cycle, the cooling system comes on but the display will not show any temperature numbers until the conditioned space gets to within 15 degrees of where you have it set to cool to. So, if it is set to 0, the box needs to hit 15 degrees before it shows numbers. You have a cooling problem. Several thing can cause this. may need a tech to check.
Sep 12, 2012 | Hoshizaki Freezers
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Kenmore Frost Free Comm. Model #253-23425100 - will not stay cold
Two things:
Either the thermostat has inadvertently been turned up, (too warm) or the gas in the compressor tank is low. If it isn't #1, call a repair tech to replentish the has in your compressor. If that isn't it he will tell you what he thinks it is. Good luck!
Mar 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My freezer is not cold enough to keep food frozen...
the "e" usually means it has an error. it could be a bad temperature thermistor or a bad control board. the most likely is the board.
i hope you are less then 1 year old as the board can be quite pricey, about 150 bucks.
you could try to unplug the unit for a few minutes and then plug back in and see if the code goes away and returns to the cooling mode.
Dec 29, 2008 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Coldtech 16 cu. ft. / 453 liter Commercial Freezer U2CRR-16S Logo
166 people viewed this question
Top Coldtech Freezers Experts
Dennis Boxerman
christian nielsen
Are you a Coldtech Freezer Expert? Answer questions, earn points and help others
