Question about Kenmore 22422 Top Load Washer
Kenmore series 80 washer: model number 110.82882800 It is leaking where the hoses connect, but only when the washer is filling with water. How do I remove the back so I can inspect the fittings and see if it is an easy repair or time to get a new washer?
  • parkerblackw Sep 26, 2009
    Can someone help me understand how to get to the top off the washer so I can remove the back to get to the hose connections?
    actually, it only leaks when the water is filling. Of course i've turned it off.
    I need to know how to take the top off so I can take the back off to look at the specific place it is leaking.
  • 986 Answers
I get this question a lot. Washer is leaking in the house, water everywhere, won't stop. The first thing I say is unplug the washer. If the water is still coming in,(which it will on a stuck valve) shut off the water faucets. If that is not possible shut the water meter off. If you can stop the washer with the timer then I would say instead of a bad valve you have a plugged water level pressure hose. Look at this diagram: Kenmore series 80 washer: - water%20level%20operation.jpg As you can see the rubber tube from the bottom of the tub allows air pressure to push against the switch till it shuts down the valve and starts the wash cycle. Remedy this problem: Simply remove the tube from the switch and blow it out. Use them lungs!. Get that sand and trash out of the sump. Reconnect the hose tightly and pump out any standing water. Then restart the machine. If you have a good tight connection the machine should start working like normal. No parts needed! LOL!
You take off the back by removing the back panel screws. Then do the procedure above and see if that helps.
Posted on Sep 26, 2009
  • Roger Campbell
    Roger Campbell Sep 26, 2009
    First of all, unplug your washer. You will need to remove the console in order to get to the top off. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
    1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
    2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
    3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
    You do not have to remove it all the way from the frame. Just enough to gain access to the switch.
    Once you've completed your repair, make sure you get the case back on the frame correctly by following these steps:
    1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
    2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
    3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
    I hope you find this helpful. If you have any questions please let me know by posting comments.
  • 490 Answers
You have to remove the top of the machine to get to the hoses
but the good thing is it is an easy fix if you can figure out how to get the top off the hoses have garden hose connections
hope this helps a little
i could never type and explain how to get the top of the machine off
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer will not fill. replaced
You will have to have an electrical test done. If it's not filling, that means there's no current getting to the fill valve. Have a qualified technician do an electrical test. But also, have him test the timer, too!
Dec 15, 2009 | Kenmore Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer leaking.
about the #1 leak on ken more/whirlpool washers are the pump.it is in the frount middle.you can dry up around washer and slide news paper under it then run load.that will narrow your surch area unless just over filling thats another matter.God bless,tom
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Dec 13, 2008 | Kenmore 24832 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Model 110.20862990 Type 111
no the timer doesn't control the water fill the pressure switch does you have three possibility's either the pressure switch is malfunctioning or a water valve is hanging open or the pressure switch pressure hose is leaking or off the tub the pressure switch is connected to the knob that lets you select the water level in the tub if you back out the two screws on the front or back of the end caps depending on the model you can pull the control panel forward and tilt it back to access the pressure switch its gold in color and has a clear latex hose attached to it also take the hose loose and blow through it to make sure its clear with the washer empty of course lol if you need more info just reply to me be glad to help water can also leak out from the pressure switch hose if a mouse has chewed through it or its come loose from the tub
Mar 18, 2008 | Kenmore 24902 Top Load Washer
Kenmore 22422 Top Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
