Question about Haier 14.3 Cu. Ft. Refrigerator/Freezer, White
Haier HTE14WABWW-02: freezer leaks into fridge. Can't find any access to freezer drain line. Tips?
  • 159 Answers
SOURCE: Haier Refridgerator
Your freezr drain is blocked or frozen. What you need to do is remove the ice rack then in the front of the freezer you will see 2 or 3 plastic plugs on the freezer floor remove the plugs and there might aso be some 1/4 inch screws farther in on the freezer floor. also remove the back of the back of the freezr and then lift out the bottom floor. under the evaporator you will see a lot of ice or just fod blocing the drain. I will bet its all full of ice. Carefully remove all the ice and hot water will help once you get the buk of it out. The hot water will make sure the drain is not blocked with ice. Once its al clear install in the reverse order and things should be good. This is a common problem with this unit.Good Luck
Posted on Jul 12, 2007
  • 833 Answers
SOURCE: Leaking water INTO fridge
Your problem is a blocked drain which prevents melt water from the defrost from getting out. You'll have to expose the coils and find the drain hole. It is possible that the problem can be on the other end of the hose...where it hits the evaporation pan in the bottom of the unit.
Posted on Jan 22, 2008
  • 547 Answers
SOURCE: Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Posted on Apr 22, 2009
landsend
  • 1066 Answers
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
  • 72 Answers
SOURCE: Air or gas leaking from freezer in Haier mini fridge
If you go to a refrigeration supply the sell an epoxy to repair the evaporator but you will need to do a sealed system repair
Posted on Jun 07, 2009
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
Haier Refridgerator
Jul 12, 2007 | Haier HSW02C
RRTG18PABB HAIER LEAKING WATER FROM FREEZER TO FRIDGE PORTION
Make sure it is not the fill tube from the ice maker first. Yes I would think ice or sludge is blocking the defrost drain and causing water to flow into freezer and then to the floor. Here is more about leaking refrigerators=> Leaking Refrigerators
Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
How to Fix Fridge Water Leak
Dec 05, 2012 | Haier RRTG18PABB (207 cu ft) Refrigerator
Water in the fridge area. plugged drain problem. how to access drain to clear
Check out these tips...they can help you figure out what is going wrong with your refrigerator
pull the bottom of the freezer up to access...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 14, 2011 | Refrigerators
Top freezer is workiing fridge is not haier preference series htp 18 gaa
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 03, 2010 | Haier (HTQ14JABRSS) Top Freezer...
Fridge won't get cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 04, 2010 | Haier HTP18GAA Top Freezer Refrigerator
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Jan 21, 2008 | Haier HTQ18JABRSS Top Freezer Refrigerator
Haier 14.3 Cu. Ft. Refrigerator/Freezer, White Logo
48 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
