Question about Garden
The right front wheel will not turn as fast as the left; if at all. The cover behind the wheel has a tear in it. I have the part but cannot get any further than taking the wheel off. Please help. Thanks
  • 389 Answers
Locate and remove the E-Clip that holds the pinion gear (the steel gear that drives the wheel) on the transmission shaft then remove the pinion gear. That is all you need to do to replace the dust cover
Posted on Oct 04, 2009
Noise from right front tire
jack up front left on level ground ,support and chock rear wheels and set park brake ---look and check the cv axle for leaks,tears or damage -put in neutral and watch axle should turn smoothly turn steering wheel to left and rotate tire again watching axle if their is binding or grinding or studder movement than axle is damaged and needs to be replaced
Apr 08, 2014 | 2005 Ford Freestar
My car stopped working after going over a speedbump
Check the battery. It is located in front of the left front wheel, behind the fender liner mounted in the bumper cover. May have been damaged when going over speed bump abruptly. Raise car, remove left front wheel, remove fender liner.
Jan 01, 2014 | 2005 Chrysler Sebring Sedan
2000 road king turn signals come on some times.the indacater light flash kinda fast if i feather the switch's they'll come on
Hi James, 1992 and later Touring Models, fuel pump fuses and relays will be behind the right side panel, starter and ignition relays will be under the seat behind the battery, everything else will be behind the left side panel to access fuses pull back on the front two locking tabs and slide the cover up. Good luck and have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 13, 2012 | 2000 Harley Davidson FLHR-FLHRI Road king
Lexus 2002 es300 front letf. behind tire makes
Yes, I would have to agree that it is a wheel bearing if the noise is only coming from the left side. Not uncommon on this year and model.
Oct 27, 2017 | 2002 Lexus RX 300
Audi A4 2002 Low beams & Right front turn signal stopped working
For Audi A4 the fuse box is located on the left side of dashboard behind a plastic cover (for left hand steering wheel vehicle). On inner face of the plastic cover you will find the fuse diagram.
First fuse on first row from left upper corner is Fuse Nr.20 = F20 (15A) - RH headlamp low beam, headlamp adjustment.
First fuse on second row from left upper corner is Fuse Nr.21 = F21 (15A) - LH headlamp low beam, headlamp adjustment.
Feb 15, 2010 | 2002 Audi A4
Clicking noise in the front wheels when I turn corners
you have an axle constant volicity joint going out. Well need to be replaces.
Nov 24, 2009 | 2001 Hyundai Accent
When i make a left hand turn it makes a howling noise can't figure this one out
It is probably your right axle bearings. How fast are you going when you turn? When you turn left, the weight transfers to the right side and loads the axles. If you are on the smooth straight stretch of highway and gently turn left and right, but stay in your lane, does it do it? If so, it's bearings.
These Cherokees are prone to rear end problems. I have one!
Jul 13, 2009 | 2000 Jeep Grand Cherokee
Plymouth breeze
My 97 Breeze battery is behind the left front wheel. Turn your steering wheel all the way to the right, and lock in position. Remove the access plate in the wheel well.
Jul 25, 2008 | 1999 Plymouth Breeze
How do I adjust the front rollers on my Roper fridge?
You just remove the bottom kickplate or grill cover. You should see a screw on the left and right sides behind that. You simply turn the screws to raise or lower the front wheels. Good luck I hope this helped. mca0824@aol.com
Apr 29, 2008 | Refrigerators
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
