My Indesit WIDL126 washer/dryer doesn't dry clothes
The washer/dryer doesn't dry the wet clothes afgter washing them; it just heats them up!
  • gospelstuff Nov 09, 2014
    FIRST CHECK UR VENTING LINES AND IF THEY ARE CLEAR AND NO KINKS U MAY HAVE A BAD HEATING ELEMENT U CAN TEST IT WITH A MULTIMETER. WE ARE TALKING ELECTRIC RIGHT? U MAY ALSO HAVE A BAD CYCLING THERMOSTAT
  • 334 Answers
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Posted on Sep 26, 2009
  • kvik Dec 04, 2012
    How to do this? Where to find the vents?
  • kvik Dec 04, 2012
    Do you simple pull out the drainage pipe?
What to do with F13 error indicator on my indesit washing machine please.
Dryer temperature sensing fault (washer dryers only)
Issue: Washer dryer is not drying clothes.
Advice: We recommend you call our customer service centre to book an engineer on: 0344 822 4224
Mar 31, 2017 | Indesit Washing Machines
Washer dryer not drying properly
the heating element of you dryer broken already
Feb 03, 2014 | Indesit Washing Machines
Indesit widl126 does not dry
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
Dec 04, 2012 | Dryers
I have an indesit widxl146 washer drier and the machine takes an age to dry clothes, 9 hours as oppose to 2 hours when new
9 Hours!!! I hope it isn't because the clothes are too wet because if it is I wouldn't like your electricity bill!!
There are a number of things you need to check.
I assume that you are not overloading the machine, and that you are using the correct spin cycle
Don't start the drying cycle directly after the wash, take out the clothes and see how dry they are after the wash, you need to ascertain if it is spinning the load sufficiently fast to dry them. How dry are they directly after the spin? If they are not wetter than they should be then the dryer is not getting hot enough during the drying cycle, this could be due to a faulty thermostat or element.
Make sure all the filters are clean including the pre chamber down below so that it can pump out the water (I guess it must be clear if it is washing ok? but check anyway.
The principal parts involved, assuming that
Also check that you haven't got a delay set for the dryer (unlikely I know but I thought I would mention it anyway)
I hope that helps.
Jan 26, 2011 | Indesit Dryers
Ive got a Indesit WIDL102 washer dryer and it will wash but will not dry any longer. It goes through the cycle but the clothes come out wet. Any suggestions???
This problem is normally caused by either the thermostats not working properly or the heating element is the problem.
Both are normally located in the air tube of the dryer down stream of the blower.
Sep 25, 2009 | Dryers
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Wil133 indesit 1300 washer dryer
look for debris in the filter,
remove the bottom front panel ( 3 screws on bottom)
Unplug washer ,
open the large access filter screw on in center , be ready for excess water to spill on floor, clean filter and be sure the pump impellers spin freely.
Feb 25, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
490 people viewed this question
Top Washing Machines Experts
