Question about Maytag MSD2756G Side by Side Refrigerator
Maytag plus refrigerater not cold enough - Maytag MSD2756G Side by Side Refrigerator
  • 53 Answers
If the freezer is cold and the refrigerator is warm, the unit is probably not going into defrost. Remove the back inside of the freezer and see if all frosted up. If so thaw with a hair dryer and replace the adaptive defrost assembly located inside the back of the refrigerator section. Up on the ceiling of the ref where you adjust the temp. remove thc cover by putting your fingers in the back holes and pull forward. Make sure the ref is unplugged. Remove two 1/4" head screws in the front and two phillip head screws by the lights. One 1/4" head screw straight in the back. The defrost timer is located in the far right corner. A small board 2 to 3" square. It will unplug and is probably screwed in.
Posted on Sep 26, 2009
Freezer not cold enough to freeze ice cream and bread.. I have setting at coldest. What else should I check?
First check the manufacturers website for troubleshooting. When refrigerator or freezer not cold enough, typically the problem is the freon is low or a more expensive repair is your compressor might be on it's way out! Sliding Pull Out Shelves Denver Colorado
Mar 09, 2017 | Refrigerators
Maytay plus need to change filter where is it and how do you change it?,
My filter is in the refrigerater .on the top or ceiling inside on the right
When mine needed changed I was lucky and found there was a replacement in the top door shelf of the freezer. Check just in case
but mine is not the same model.
Nov 16, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refrigerater not staying cool 52 degrees
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Maytag Refrigerators
REFRIGERATER SIDE IS NOT COOLING BUT THE FREEZER IS WORKING
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
qreq
May 10, 2010 | Maytag MSD2756G Side by Side Refrigerator
"maytag plus wide by side is not getting cold enough"
The defrost thermostat is failing on these machines as well as the adaptive defrost control.
The compressor start relay is on recall from Maytag also.
Apr 10, 2009 | Maytag MZD2766GES Side by Side...
My freezer and refrigerater will not get cold
u would have a leak in your sealed system if the fan and compressor are working and still not cold very expensive to fix
Mar 18, 2009 | Frigidaire FRT21H8 Top Freezer...
MY Maytag Wide by Side freezes in the produce drawers.
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.
p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit.
Thank you,
Rick
Jan 21, 2009 | Maytag 26 cu. ft. Wide-By-Side...
Refrigerater not staying cold and coil is frozen. condenser and fan are working freezer ice machine not working
The tube between the freezer and fridge is also likely to be frozen up. You need to unplug the unit for a day and let it thaw out. When you plug it back in, start with a low to med setting on the temp.
Geno
Aug 02, 2008 | Maytag Refrigerators
Maytag refrigerater
If you have an ice maker in the freezer compartment try raising the bail arm and shutting it off. It is possible that an ice maker will increase your run time.
May 16, 2008 | Maytag Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
187 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
