Question about Fuji FinePix Z100fd Digital Camera
Also receiving Focus Error and unable to take pictures now
My camera is just over 1 year old and I am receiving the Focus Error message, I used the camera 12 hours earlier with not problems.
Hi. I have a Fujifilm A235 12.2 MP which I bought around 1 year ago. Once I tried to switch it off and it told me "Focus error". From that day on the lens would not move in and out as usual and I...
Hello
Unfortunately a "focus error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Mar 19, 2011 | Fuji FinePix A400 Digital Camera
Camera is 3 years old. Lately I take a picture
All the battery have a life time fixed working hours. Your battery is charged but he complete is working time. Thats why these msg will come. Dont warry use the battery when you see the power going down after a while of charging then change the battery and buy new 1. Good luck.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
Dealy on snapping pictures
Check your focus modes to see if you are using one that is different to usual. When a DSLR has no focus lock it won't take a picture. Also verify that the focus motor in the lens is working ok. Google 'lens focus tests' and see what you can come up with.
Sep 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D40 vertical focus problem
Make sure the camera is using the appropriate focus sensor.
Does the problem occur when you focus manually?
Are you handholding the camera? Many people don't hold the camera as steady when holding it vertically. Try putting the camera on a tripod or other steady surface and see what happens.
Jun 11, 2009 | Nikon D40x Digital Camera
Focus error message camera wontwork
I found this site to solve this problem. I got as far as tapping the lens, while turning it off. That worked but I still could not take pictures, so, I got the idea to put slight pressure on the lens when turning the camera on and was delighted to see that the error message was gone. Then, reluctantly, I snapped a picture...It worked. Hope this helps u 2..
Mar 29, 2009 | Fuji FinePix A500 Digital Camera
Quantary Tech-10 75-300mm use with Canon Rebel XTi
Hi all
On most lenses the way to test if your old lens works on a cannon digital to set the camera to AV then set the iris to the small setting ie F16/F22 then use the stopdown button.
Things that might happen
1 The lens will close down OK
2 The error 99 will show,will need are rechip if avaliable
3 Nothing happens, will need a rechip
Q.Why will it work inside but not outside.
A. Inside the camera needs light so the iris is full open, outside the lens needs to close down and if not compatible it is unable to close down. will need a rechip
Mar 12, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 for...
Absolutely screwed up, recently purchased camera
try to shoot without a card. or better use a known good card. [:0)
Jan 10, 2008 | Canon Rebel XT / EOS 350D Digital Camera
E-mail pictures using Kodak EasyShare software
when I send a picture, the envelope shows sending but it never goes thru to the recipient.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Fuji FinePix Z100fd Digital Camera Logo
206 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
