Question about Philips Magnavox 9P6034C 60" Rear Projection Television
The enitre screen is green and red and the pictures are doubled
  • Philips Master
  • 3,459 Answers
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 27, 2009
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Televison & Video
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
michtech
Feb 16, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 11, 2008 | Samsung HC-P4752W 47" Rear Projection...
I have 47 inch with double color in picture, reds and green
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
