Question about Cosco Juvenile 22209WAL Booster Car Seat
Need picture instructions for this car seat - Cosco Juvenile 22209WAL Booster Car Seat
Can you tell me if I can remove the seat cover and hood from the maxi cosi car seat to wash? If so how do I do it? many thanks
If you go to http://www.maxi-cosi.com/ot-en and select the car seat you have, ie. CabrioFix, it will show you a picture in the middle of the screen with 4 tabs across the top. Underneath the picture are 3 options, Specifications, Instructions and Instruction Movie. Select Instructions and this will take you to the Instruction Booklet you should have got with the seat (if its not alread tucked in its holder at the back of your seat). There is a section in the booklet that shows/tells you exactly how to get the covers off for washing. Good Luck
Jun 17, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
HOW DO i GET THE COVER OFF TO WASH??
If you go to http://www.maxi-cosi.com/ot-en and select the car seat you have, ie. CabrioFix, it will show you a picture in the middle of the screen with 4 tabs across the top. Underneath the picture are 3 options, Specifications, Instructions and Instruction Movie. Select Instructions and this will take you to the Instruction Booklet you should have got with the seat (if its not alread tucked in its holder at the back of your seat). There is a section in the booklet that shows/tells you exactly how to get the covers off for washing. Good Luck You could try Kiddicare.com for the head support.
Jun 11, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
Dont know how to use seat with car seatbelt
It's impossible to tell without more information. There are usually pictures and instructions on the sides of the seat. I believe that your nearest fire station will help you, and that is probably the safest route to take. Good luck to you.
Sep 23, 2009 | Baby Gear
I need an instruction manual for the Scenera Convertible car seat model # 22113BVL
You can visit this link to download PDF instructions. You need the manufacture date and it should be printed somewhere on the car seat in mm/dd/year format. Hope that helps :)
http://www.coscojuvenile.com/usa/eng/Instructions
Aug 30, 2009 | Cosco Juvenile Scenera Convertible Car...
Nania car seat
I BOUGHT BRAND NEW NANIA CAR SEAT BUT NO INSTRUCTIONS, FROM ARGOS!! YOU NEED TO CONTACT THE MANUFACTURES WHO ARE CALLED Team-Tex and the uk contact no. for them is 0116 284 4910, they will send you the manual that you need.
Dec 19, 2008 | Baby Gear
Car seat instructions
Here is the link to the online manual for the 2007 Perego Car Seats. give it a few seconds to load. It will be a white page while it loads.
http://www.pegperego.com/pegcatalogue/juvenile/downloads/PrimoViaggioSIP-US_FIUS0603I61.pdf
Follow the remove instructions in reverse. It is difficult to describe, but the pictures are very helpful.
Good Luck! from Moms Just Know
Sep 30, 2008 | Peg Perego Primo Viaggio
Mutsy traveller car seat
Hi
We have the same problem!!
You can download the manual in PDF from this www:
http://www.mutsy.nl/products/traveller/technical
But, you need to register first, and know the serial **- which we CAN'T READ!
The serial ** supposed to be on a white sticker at the bottom of a product.. but I can't read it, so we can't register!
If you will register, is it possible to forward the manual to us?? I'm really worried about fixing the car seat with the pictures at the back of it, cos I also think it shouldn't be so loose..
Here's my e-mail:
anjako.com@gmail.com
Hoper this help
RGDS
Anna
Feb 16, 2008 | Baby Gear
Washed liner, need to know how to put car seat back together
I have a Graco LiteRider Travel System car seat and I took it all apart to clean it and I cannot figure out how the straps in the back are supposed to go. Does anyone have a picture of the back of one thast I can see?
Aug 21, 2007 | Safety 1st Designer 22-325
Evenflo infant seat installation
Here is a link to a PDF that has pictures. I think it is fairly comprehensive. Good luck and good for you for double checking! http://www.carseat.org/samples/Sample_Summary.pdf
Jun 07, 2007 | Evenflo Discovery - Midland Blue
Cosco Juvenile 22209WAL Booster Car Seat Logo
73 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
thegtw
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
