Question about California Audio Labs Toys
CAL-20.Ability to play back DAD discs
Hi!
Perhaps You know how to unlock CAL-20 to make it play back DVD ( DAD) audio discs?
Regards - Jankon
  • 1 more comment
  • kondajan Sep 27, 2009
    Hi
    The only option I can get when I enter the set up utility ( and then rating) is the level of parental control on desplayed DVDs.I can change between 1,2,3 by submitting a 4 digit password.I can not proceed anywere from this point. .There`s no such an option as MISC SETUP.Please explain me again step by step how to do a factory reset.Regards - Jankon
    Hi (again)
    There`s no such a option as Misc Setting.Maybe we`re talking about different dvd players.Mine is CL-20 by California Audio Labs.This is what I have done trying to access the settings:
    1.With disc removed I pressed the SETUP button on remote
    2.There appeared a SETUP menu on a tv screen with 6 choices:rating,audio,subtitle, tv screen, osd display,menu language.
    There`s no Misc Setting in any of them nor in main Setup.Please tell me what have I done wrong?Regards - Jankon
  • kondajan Sep 28, 2009
    Thanks for Your suggestions.It seems problem is with my CL-20.It still doesn`t play DAD layer on multiformat DVD.
  • 615 Answers
That is funny as this is got very good reviews see http://www.avrev.com/home-theater-audio-sources/cd-players/california-audio-labs-cl-20-dvd-cd-player.html
Did you try it with others? It may be just this one…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 27, 2009
    President:
  • 1,462 Answers
HI,
Just select settings and you can get ratings by pressing the UP arrow, till you get.
Once you get rating, you can change the rating and if it asks for password
If you forget your password, please usethe universal password 0000 to unlock.
And try to do a factory reset. by choosing MISC SETUP and load factory defaults
This should enable your CAL-20 to play all DVDs
leave me comment,if you still need assistance
RNJ VINODKUMAR
  • Vinod Kumar
    Vinod Kumar Sep 27, 2009
    You have the lst option in the menu, which is called Misc Setting, and from that you can choose Factor reset to default setting, It is the bottom last item in the menu..
    RNJ VINODKUMAR
I have not been using my HT for almost a year. When I tried to play DVD now, I get the message "This type of disc can not play". Strangely my system accepts and plays a MP3 audio disc!! When I...
it could be that your lens has lost its ability to read dvd discs but retains the abaility to read the audio cd you used. If this is the case (and a cleaning disc doesn't help) then I am afraid that the service centre was correct in its assumption.
Hope this helps.
May 08, 2011 | Panasonic Home Theater System System
Region Code Unlocking for the Panasonic DMP-BD30K 1080p Blu-Ray Disc Player
Not all models have a known unlock hack, let see this one.
Aug 28, 2008 | Televison & Video
Hello, I have jusy bought a HTS3011 home theatre system, but I had try to play a lot of dvd s, and I had an error related to the disc regionin the most part of the discs I tried. Can someone help me? As I...
Hello Patricia -
Please follow the instructions below for unlocking your Philips HTS3011
1. Switch on the DVD player
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the DVD player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Regards,
BElectric
May 01, 2011 | Televison & Video
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
1. Switch the DVD player ON
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
PANASONIC SC-BT200 UNLOCK REGION CODE
Google for "Panasonic SC-BT200 Region Free
Also see
"http://www.avforums.com/forums/blu-ray-players/885440-blu-ray-player-multi-region-hex-codes.html"
Some Blu-Ray players will need a hardware mod to be region free.
Feb 05, 2010 | Panasonic SC-BT200 Home Theater Systems....
New DVDs - New Problem
Same speed U bought 1-4x 1-8x 1-16x make sure have same speed disc.
Dec 17, 2009 | Sony RDR-VXD655 Recorder
LG DVD PLAYER DV8621P
Turn on the unit, with remote, (no disc in player), press pause, then key 3 1 4 1 5 9
Instructions for changing region code appear on screen,
Set to Region or Disc you want to play, 1, 2, 3, 4, 5, 6, or 0 for all. Press pause again. Turn off machine.
Jun 26, 2008 | LG Televison & Video
DVD problem
It could be a couple things...
#1. Over time, dust and deposits can accumulate on the laser that reads the disc. In many cases, DVD players with this problem can still read CDs. You could try a DVD laser cleaner, which is usually a disc that has a tiny brush glued onto it. Run the cleaning disc 2 or 3 times, and try it again. Try both CDs and DVDs, since CDs are easier to read than a DVD.
2. After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. In many cases, DVD players with this problem will still be able to read a CD. I'd try a cleaning disc first, since the only way to fix this problem is to bring the unit to a service center for repair.
Let me know what happens after you get the DVD laser cleaner and run it. Hope this helps.
May 07, 2008 | Televison & Video
Samsung portable dvd player
those kinda players wont play DVD rom disks and certain ones that are made up. DVD-RAM or ROM wont work. Try blowing inside the player for any dust. if it still doesnt work its the maufacters problem. The player will play CD-G audio only, not graphics The ability to play back DVD-R, DVD-RW, DVD+R, DVD+RW, CD-R, CD-RW, and CD-Jpeg discs may depend on recording conditions.
Jun 25, 2006 | Verbatim (94562) Media
Toys Logo
60 people viewed this question
Top California Audio Labs Toys Experts
Andrew Taylor
Andrew Taylor
Are you a California Audio Labs Toy Expert? Answer questions, earn points and help others
