Question about Uniden Cordless Phone
Landline, cordless phone - static on outgoing calls only. When others call us, the line is clear.Seems to be a particular problem with long-distance calls, less of a problem with local calls.
Static on land line phone . Sometimes worse then ohers
Posted on Apr 12, 2010
How do I get caller display for which I pay BT extra to work on my handsets when it works fine on the landline on my property. I have checked Blocked calls list etc but still get No Number displayed i
Do you have DSL on the same phone line? I have seen where the 58 GHZ phones sometimes are not compatible with it because of the WiFi being on the same freq. and thus stop the CID signal from coming thru. There also might be a distance issue or some type of filter on your line causing the trouble. The CID signal is sent thru between the first and second rings of the phone. So if you can get a phoneman's headset and connect it to the line to listen when the phone rings, you should hear a kinda static between the first and second rings. If not then you aren't even getting the signal to the phones.
Apr 23, 2014 | Vtech CS5111 58 GHz 1Line Cordless Phone
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
Apr 29, 2009 | Philips VOIP8411B/37 IP Phone
Static on line
Does the static stay on the line after the called party answers?Is the static on incoming and outgoing calls on any phone?if the answer is yes to the above questions,check your house jacks for corrosion.There are a number of things that can cause static inside your house and outside.From the interface box on your house where the wires come from a pole or from under ground is phone company problem.From the box into the house is your problem,so the easy solution is to make the phone company come out and determine from what side the static is coming from.There is usually no charge for this unless you have them come into your house if the problem is there.
tk46
Jul 20, 2008 | Panasonic KX-TG1033S Cordless Phone
My landline phone does not work. I tested it outside on the company's jack and the phone works. I have 3 jacks in the house and it will not work on any of them, including the one I get the internet. The...
One of the phone handsets of the Panasonic KX-TG563 trio gives me static w/ dial tone and then shuts down or it gives me the message that "System is busy/Line in use" with no dial tone. If I get closer to the base unit it seems to work but w/ alot of static. The base unit phone works good and the other handset works ok too. The battery shows fully charged however, when I take the battery out to try a reset when I put it back in the battery indicator show very low. I tried switching batteries w/ the othe hand sets it doesn't help.
Thanks
Jun 07, 2008 | Lands Phones
Faxing problem
1) Plug a single line wired (not cordless) phone in to the exact same phone jack as the fax machine and dial one of the fax numbers you are trying to dial out to using the exact same digits. Does the call complete Y/N? do you hear a fax tone Y/N?
>>>>If either answer is "No" you have an invalid phone number. If both answers are "Yes" proceed to step 2.
2) When you off hook do you hear a "stutter" dial tone? Y/N?
>>>>>"Yes" This is your phone company telling you that you have unlistened voicemail messages in your mailbox. Dial in to your voice mail and clear your messages. "No" go to step 3.
3) 2 part question: Do you have call waiting and is your fax machine trying to disable call waiting when dialing out?
>>>>>In many areas *70 (star-seven-zero) will disable call waiting for a single phone call. If you try to disable call waiting when call waiting is not on the line, the call will not complete. This may come in to play in a speed dial situation.
+++Other things to consider+++
*Is outgoing long distance blocked on the line?
*Is outgoing regional intralata (same area code) long distance blocked?
*Is local calling blocked?
*Is a speed dial misprogrammed? Forgot to dial "1" Dialed "1" in error?
*Is there a wiring problem? >>>Try moving fax machine to a different phone jack.
There may be no magic answer for your problem, I hope one of these suggestions helps.
Nov 16, 2007 | Brother MFC 240C All-In-One InkJet Printer
Uniden Cordless Phone Logo
394 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
