On an SDT S9000 EXTERNAL drive the tapes do not fully eject and thus break on attempted removal.
  • 64 Answers
SOURCE: Can't eject tape
The main chassis has a problem with it its very easy for them to break when that happens it needs to be replaced sorry if you need the tape i can post back how to get it out you would need to take it apart but its easy
Posted on Dec 22, 2007
JaxPlanet
  • 922 Answers
SOURCE: ultrium tape stuck
I highly recommend that you contact Certance for assistance. Tape drives are expensive and you don't want to risk damaging it.
If you are feeling brave you could see if you can manually eject the tape.
Remove the tape drive from the chassis and look for a manual rewind screw on the bottom or back of the drive. This is provided on some drives to allow you to manually wind the tape back into the cartrige and eject it.
I hope this helps.
Posted on Aug 11, 2009
  • 74 Answers
SOURCE: Tape not ejecting from drive after 60 secs pressing eject button
can you detail the model No or compaq spares No for the drive - the clicking makes it sound to me like a DAT but unable to proceed without more info.
If it is a DAT (compaq used both Sony and HP mechs) try disconnecting the scsi cable from the scsi card, rebooting the drive and trying again.
If that doesnt work try a 00pt screwdriver in the manual eject point of the drive and unload manually (about 1000 turns!)
Failing that try www.tape-drive-repair.com as they are pretty good price wise for a repair / exchange
Posted on Aug 24, 2009
  • 19 Answers
SOURCE: I have hp surestore DLT1e drive. Tape cartridge stuck!
For that you can try to press and hold the eject buttonfor 30 seconds if the tape doesn't came out then reflash the drive firmware revision.
After all that is the issue persists you can try to:
manually remove the tape by removing the top cover
Locate recessed thumb wheel
Rotate thumb wheel counter-clockwise until you feel resistance. Wheel may spring back when you release it. This is OK.
Locate hole in bottom of drive. Insert #10 Torx driver and rotate clockwise until tape ejects. If there is a lot of tape on the take up reel, this could take some time.
Rotate thumb wheel clockwise to eject the tape.
Posted on Aug 12, 2010
domotek
  • 591 Answers
SOURCE: HP DAT 160 USB Tape
you could try opening the drive and delicately untagle the tape (with tweesers) dispose of the tap as it will get stuck again
Have fun!
Posted on Jan 04, 2011
Ive just bought an old sony dat drive SDT-5000 and want to use the external housing frome one I already have. Does anyone know how to set the jumpers? I can supply an image of this if it helps
supply an image (and would be great if you could supply image from old broken one and new one)
I'm a bit confused though: if you have an internal working sdt-5000 that you want to put into an external broken sdt-5000, it should be as simple as getting the enclosure open, then swapping the internal drives; i.e. external enclosures usually still use the same spec internal drive so it would just be an ide or scsi connector cable.
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
Jul 12, 2016 | Sony DDS SDT-5000 DAT Tape Drive
Item: DLT tape drive ( DLT8000 SCSI LVD Loader For Scalar 100 )Problem: Eject spring not fully loaded, as the result pick up tape unable to reach to pick. Please advice.
Look at this document to see if the interposer mechanism is holding the tape from ejecting. The solenoid that energizes to tape insertion or ejection sometimes relaxes and you have to move it manually out of the way to recover the tape.
http://www.filibeto.org/sun/lib/hardware/storedge/tape/l280/pin-024.pdf
Jul 28, 2011 | HP DLT8000 HVD/SCSI Loader (c7200-69978)...
Tar /dev/st0 can't write: error
Sounds like your tape drive or possibly the tape you are using is faulty.
check the following:
#1 - use a different tape
#2 - check that the read-only is not enabled on the tape(s)
#3 - run diagnostics on the drive (if it's come with software for diagnostics).
#4 - return it to the supplier to test and replace if under warranty.
Apr 04, 2010 | Sony DDS SDT-S9000 DAT Tape Drive
Hi I need to manually remove a tape from a quantum 3 superloader. The tape appears to be stuck in the drive
Hi Adrian
I would suggest sending it to www.tape-drive-repair.com for them to fix as once the tape has been removed you will still probably have the original fault that caused the tape to get stuck.
If you do try and remove the tape yourself be extremely careful as those drives are very easy to break the load mech and tape leader assy if you dont know exactly how to remove them.
Bear in mind the tape may not actually be stuck though!
Try powering off and on the loader with it disconnected from the server just in case it is your backup software not letting the drive eject the media as this is a common issue (where the software tells the drive it is using the tape (or hasnt finished with it) and stops the eject button from accidental operation)
Aug 17, 2009 | Quantum LTO-3 (BHWCXEY) LTO-3 Tape Drive
I've got a 3580 Ultrium tape drive with a tape that won't eject and the unit displays error code 6. Is there a trick to get the tape out?
I had this same problem a few mins ago. I held the tape up with my finger as I hit eject. The tape came right out. Then I put in a cleaning tape and had no issues at all. You don't need to disassemble the unit at all.
Jan 06, 2009 | IBM TotalStorage 3580 L33 (3580L33)...
Can't eject tape
Dec 17, 2007 | Canon ZR600 Mini DV Digital Camcorder
My Drive will not eject the tape
Turn off the tape drive. (Switch in the back of the unit. Wait 2 minutes and then turn unit back on. Tape drive should issue a write data command and then rewind the tape. After rewind completes the tape should eject. If it does not eject after rrewind completes than try holding the eject button for 5 seconds to attempt a "force eject"
Note: Do not repeatedly press the eject button as this can cause damage to the tape and the tape drive.
Dec 07, 2007 | Quantum SDLT 320 External LVD...
44 people viewed this question
k24674
jasbo
jasbo
