Question about HP PSC 1315 All-In-One InkJet Printer
Printing off center
I am printing note cards. My HP PSC1610xi prints the first card on the sheet dead center but the second is about 3/16" off center. I have checked the template and I am using the correct one. I have used the same program and file on an Epson and both cards are centered. I would rather be using the HP for several reasons but a 50% loss is unacceptable
    Genius:
  • 1,003 Answers
To cure your registration problem :
open the top cover (printer off ) moisten a microfiber towel with isopropanol alcohol then wipe all the rubber paper feed tires off to clean them.
Then try to print the note cards .
This is a traction related problem.
Posted on Jan 17, 2008
Hp 5520 will not print from sdhc card
From what I can tell from the specs, the 5520 works with SD cards, 2GB and smaller. It won't work with higher-capacity SDHC cards.
Mar 15, 2013 | HP Hewlett-Packard - Photosmart 5520...
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
Can't print envelopes made by "Greeting Card Factory" v7 on an HP B209a-m. Cards (.fgc file) print OK but envelopes (.fev files) won't print (envelope won't go into the print area; spoolvs.exe take 99% of...
The problem centered around the fact that the HP209 would only print 8.5X11 sheets from Greeting Card Factory. Any other size seized up the pring spool.
We're going to return the HP (We think it's defective) and get an Epson.
Nov 23, 2009 | HP PHOTOSMART PLUS B209A All-In-One...
Printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    WHAT SETTING DO I NEED MY PRINTER PREFERENCES NEED TO BE ON TO PRINT A 51/2 X 41/4 NOTE CARD FOR A HP OFFICE JET 6210?
    We need to manually set the size to print on the card size, go to HP Director or HP Solution center then settings >> print settings >> printer settings and manually set the size and then print.
    May 22, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Dell 924 All-In-One printer
    Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
    • Letter*
    • Legal
    • B5
    • A4
    • A5
    • 3x6
    • 4x6
    • L
    • 2L
    • 5x7
    • Hagaki
    • 10x15 cm
    • 13x18 cm
    25 greeting cards,
    index cards,
    postcards, or photo
    cards
    • The print side of the cards faces up.
    • The cards are centered on the paper support, in between the left and right
    paper guides.
    • The paper guide rests against the left edge of the cards.
    • You select Normal or Photo print quality.
    25 sheets of photo
    or glossy paper
    • The glossy side of the paper faces up.
    • The paper is centered on the paper support, in between the left and right
    paper guides.
    • The paper is loaded vertically against the right side of the paper support.
    10 iron-on transfers • You follow the loading instructions on the packaging.
    • The blank side of the transfer faces up.
    • The transfer is centered on the paper support, in between the left and right
    paper guides.
    NOTE: For best results, iron-on transfers should be fed one sheet at a time.
    50 transparencies • The rough side of the transparencies faces up.
    • The transparencies are centered on the paper support, in between the left and
    right paper guides.
    NOTE: You can load a single transparency into the paper support without
    removing plain paper.
    Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
    Can't Print on Card
    I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
    Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
    To access the rollers, remove the scanner plate:
    1. Disconnect power, USB, and phone cables.
    2. Open up the scanner sheet feeder by tilting it left.
    3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
    4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
    4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
    5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
    6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
    Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
    HP 1310 series
    I have an HP PSC1315 which is virtually the same printer. I actually created my own template where 10 business cards are printed as if it were one sheet of paper(like a poster). Of course you you can't select how many cards print, or which card to start on, but at least I get 10 perfectly centered cards.
    Sep 04, 2007 | HP PSC 2210xi All-In-One InkJet Printer
    HP PSC 1315 All-In-One InkJet Printer Logo
    87 people viewed this question
    Clive
    Clive
