Question about Canon Cameras
Cannon powershot 315 is taking grainy pictures/won't always allow
To take pictures. Shutter does not activate when button is pushed.
    President:
  • 2,761 Answers
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
My cannon powershot S5IS used to take great pics...now they are almost always very grainy. do i need to fix a setting or something? i have no idea!
Please see if the mode forr picture is set to normal, Try to select auto mode and then manual mode to see if there is any change.
If you notice that the grains come on in low light, try pictures in good light to confirm. If still bad the camera needs a check for a faulty imager unit./the CCD might be defective.
Take an estimate to decide.
Aug 25, 2010 | Canon Cameras
How do I change the shutter speed?
This is "shutter lag," the delay between pressing the shutter release button and the camera actually taking a picture. This is a common situation with many compact cameras. The camera has to focus on the subject, meter the exposure, and switch the circuitry from displaying on the screen to recording the image and saving it in memory. More sophisticated (and expensive) DSLRs eliminate this shutter lag by having more dedicated hardware for this.
With a compact camera, you can reduce the shutter lag by anticipating the shot. Press the shutter release button halfway to focus and meter the exposure. Continue to hold the shutter release button halfway until the right time, then press it the rest of the way.
Jan 17, 2010 | Canon PowerShot SX100 IS Digital Camera
Cannon Powershot A-620 black screen can't review
Did you accidentally press the DISP or DISPLAY button on the back of your camera? This manually turns the screen on and off to save batteries. You would then use the optical viewfinder to take pictures. To turn the screen back on, just press this button one more time.
Jul 23, 2009 | Canon Cameras
Camera takes white pictures in daylight
Sounds like over exposure due to the shutter not closing all the way. test video out. should work fine. shutter mechanism will need cleaning
Apr 25, 2009 | Canon PowerShot A630 Digital Camera
Out of focus pictures
Try allowing the camera to focus by pressing the shutter button halfway.  Wait for a beep then press the rest of the way to take the picture.  This should result in much sharper images.  If this helps please rate my solution.
Dec 11, 2008 | Canon PowerShot A75 Digital Camera
Help
Check:
1 - If you're on a shooting mode (not on a video mode);
2 - If you have enough power from batteries (maybe flash is necessary and power is not sufficient...);
3 - If memory card is in...
Try it...
Aug 02, 2008 | Canon PowerShot A700 Digital Camera
Grainy photos
just switch to regular mode but the pictures already taken will unfortunately be like this sorry
Mar 18, 2008 | Fuji FinePix F10 Digital Camera
Grainy pictures
grainy pictures are possibly casued by a very high ISO (sensativity) setting, you should be on 100 or lower for best normal shots. Higher settings are for low light and custom shooting in strange lighting or aperature/shutter speeds. Try full auto setting.
Mar 03, 2008 | Canon PowerShot S3 IS Digital Camera
G5 Powershot Cannon
I posted this on another link to this site where they were having the sam eproblem so this may work for you.
OK, I think I worked it out. The shutter button was not working correctly. They wanted at least $182 to ship it off to a Canon repair facility. Give me a break! My husband spilled coffee on his personal laptop and then several weeks later spilled juice on his work laptop...I'm thinking...hello...learn any lessons yet. Anyway, he couldn't get the keyboard to work properly on his personal laptop (apparently it didn't like all the caffeine) so he bought some Precision Electronics Cleaner at Radio Shack and tried to clean it. That didn't work so we had to order another keyboard. But, that gave us the idea to try the cleaner on the shutter button. The button worked fine in the half way down focus position so we figured the spring under the button was still working but the contact when you pressed it all the way down was not activating the shutter. If we jiggled the button a bit it would take the photo so that meant the contact needed cleaning in order to take a picture with out mashing or jiggling. So short story long, I sprayed some in there and then blew some air into it to dry it out a bit quicker. The spray evaporates anyway, but that just sped up the process. It works like a charm now!!! YEAH!
Let us know if this helps. Good Luck!
Colleen
Feb 04, 2008 | Canon PowerShot G5 Digital Camera
Cameras Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
