Question about Brother MFC-7820N Laser Printer
The front door on the left side would not open to release the drum unit. The lever broke and needs to be replaced where can I get the part, schematic and repair it myself?
Where is the drum on the MFC-8860DN and how do I remove it?
The drum is part of the laser toner cartridge
Open the front door
Press the square button in the center of the paper receiving are, it is marked with a small triangle
Press and pull, it will open a door showing the toner cartridge
Pull out the toner cartridge
The top part is black and the bottom assembly is grey
There is a blue little latch in the right side of the cartridge
Press the latch and the toner cartridge will be release
Remove the toner cartridge.
You need to replace the grey bottom assembly with a new one
A compatible assembly, which will have a new drum, will cost around
$30 at amazon an oem around $70
Reassembly and reinstall in reverse of the disassembly
I hope this was helpful
Mar 17, 2015 | Brother MFC-8860DN Printer
Ricoh SP C811DN has a sc 400 error code
open the front door and left door, take out the drum unit after releasing the lock lever if look at the opening from the right you can see a black sensor unit facing inward towards drum clean its inner side with a dry cloth and put back everything it is the id sensor, machine should work now
Apr 03, 2014 | Ricoh Aficio SP C811DN Laser Printer
Where are the cartridges located to install new ones?
http://software.canon-europe.com/products/0010476.asp
try to download the manual from the above link and check there.
Howver you can also check it on the lid. instructions are given. This should be very easy as we need to pull out the tray and replace the cartridge. signs and signals are given on the printer itself.
Apr 29, 2011 | Canon iR 2022i Printer
I am a tech and have to replace the drum on a copystar CS 1635. The service manual has been lost so I need the instructions.
open front cover, remove toner cartridge and waste toner tank. unscrew the screw below the developing unit and release the dev unit by pulling the lever. open left cover. from the front remove the screw on your left holding the drum unit. gently pull out the drum unit and replace the new unit using. the reverse procedure to be used.
Apr 20, 2011 | Kyocera Copystar CS-1635 Copier
Waste toner full..
Open the front door and the left door.At thefront door were you remove the toner,next to the toner there is a blue lever.Release the leaver and remove the drum unit.On the drum unit there is a plastic plug remove the plug and though all toner in the dusbin.Do not use this toner again.
Feb 17, 2010 | Canon imageRUNNER 2018 Copier
Brother mfc 9700 need to change toner cartridge but drum wont come off, how do i get this off safely and back on again?
If you open the door and the toner doesn't release, there may be a broken gear on the left side that releases it. The black lever on the left side of the door disengages the toner and when that doesn't pull freely the gear inside is broken and a shop needs to replace for you. If just the toner, you press the blue lever and lift the toner off of the drum.
Jan 19, 2010 | Brother MFC 9700 All-In-One Laser Printer
Can you tell me how to replace the transfer belt imaging unit?
First you open the left side door, then press the button and lift the top cover, the transfer unit is the first on top with a handle and levers to release. The drum unit is under that also with blue levers to release.
Jan 12, 2010 | Samsung CLP-510 Laser Printer
Irc3380i drum
this the procedure how you removed the drum in irc3380 machine. first open the front door and remove the small cover in your right side.then open the side door.and turn the black lever to right.then push the other lever at the top of blk lever.then remove the 2 screw in both side its locate near in the blk lever in right and the other screw in your left side opposite of the other screw,then when you remove the screw pull the unit out.and you will see the square button at the top off thegray cover plastic in the rear side.push that button and pull it out.and in the rear side you will see a small blk lever to hold the itb unit.(take note not to touch the surface of the itb belt the shiny black one.then you will see the 4 color drum.unlock first before you take out the drum
May 12, 2009 | Canon Office Equipment & Supplies
Severe paper jam and don't know how to remove toner drum
To remove the toner/drum unit you need to open the front cover, you will be looking at the toner/drum unit, the blue lever should be on the left.
Look in the middle of the toner/drum unit, if you put your hand in there you will feel kind of a "lip" where you can pull out the entire piece. The toner fits into the drum unit so when you remove it it is one piece. That little blue lever releases the toner from the drum unit. You should need to push the blue button.
Once you have the toner/drum unit out you can reach into the guts of the printer and retrieve your paper that was jammed.
You need to then replace the toner/drum unit, it will slide back where you took it out from. It may be difficult to push, you need to add a little force and it will go back into place. Close the front door and you should be all set. You may need to push the "go" button again, I can't remember for certain. Make sure that all of the doors have been closed tight.
Feb 17, 2009 | Brother HL-2040 Laser Printer
Replacing Belt on Jenn Air CLothes dryer
1. Disconnect power
2.Use Putty knife and push in to release two spring catches between top and front panel about 3 inches from either side. Top then lifts up. Undo two hex screws on either side of side panels close to top. Front panel then tilts forward. Un-clip door switch and wiring harness before lifting off front panel. If belt is broken, drum should lift off by slowly raising front of drum to disengage wheels at rear of drum.
3. clean accumulated lint from inside fan housing and duct work on front panel as well as from total inside of dryer base before placing new belt around drum, smooth side up before carefully replacing drum in place to engage two wheels at rear of drum.
4. reaching left hand under drum, raise spring loaded idler arm and place ribbed side of belt around pulley on end of motor with right hand before releasing idler arm to provide tension on belt.
5. Place front panel on bottom clips and reengage door switch wiring harness before reattaching hex screws at top of side panels.
6. drop top pannel of unit in place to reengage spring clips before reconnecting power
Dec 24, 2007 | Dryers
Brother MFC-7820N Laser Printer Logo
51 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
