Question about Tripp Lite Smart Pro UPS System
I just bought a tripp lite ups G1000U and the display keep blinking every 10 seconds.
4 Suggested Answers
  • 3 Answers
SOURCE: Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Posted on Oct 19, 2010
SOURCE: Tripp Lite
Sorry but I was not able to repair the problem
Posted on Aug 22, 2008
  • 225 Answers
SOURCE: tripp lite avr 550 ups
Check the fuse. Check the input voltage. Since it's AVR, it keeps discharging if the input voltage is below the minimum
Posted on Aug 05, 2010
The power wents off and the batery got completly discharged , then i turn it on and run the self test and replace icon staid illminate but in the next self test didn't, i hace to replace the battery?
First tell how old is your UPS ?
if its older by two to three years may be the Battery eeds a replacement .Try charging the battery externally with a good battery chargers but before charging externally please take out the battery outside.
Then if the battery shows very low voltage even after charging for some 8 hours then you have one alternative that is replace with new battery.and promptly keep it under charge with out fail.
Aug 16, 2014 | Tripp Lite G1000U Intelligent LCD 1000VA...
Line voltage indicator false indication of voltage variations
Voltmeters usually read RMS on ac volts therefore 120 volts is OK while the indicator is reading peak volts. If unit is operational there is no problem.
Mar 31, 2014 | Tripp Lite G1000U Intelligent LCD 1000VA...
Replace battery in G1000U
Go to http://www.tripplite.com and find model number for instructions how to change battery.
Feb 28, 2014 | Tripp Lite Computers & Internet
UPS stopped working
I appreciate the suggestions. Let me add some additional detail that might help me get more helpful suggestions.
The display on the unit is completely blank (black) with nothing showing. I've tried unplugging everything from all outlets and pressing the on/off button and holding it for more than 1 sec. and no matter what I've tried the display won't show anything so there aren't any red lights, or visual clues what's going on. I only know that items plugged into the non-battery backed-up outlets work and items plugged into the batter backed-up outlets don't.
The owner's manual says it's not user serviceable and I've been able to find the compatible battery online, but I'm not inclined to spend the time/money until I feel more confident it will solve the problem.
Any thoughts on how to diagnose and then resolve the problem?
Thanks,
Randy
Feb 03, 2013 | Tripp Lite G1000U Intelligent LCD 1000VA...
Tripp.lite ups fault displayed and beeping
My Tripp Lite was showing a fault this morning for no logical reason, ran this self test as suggested and all cleared. Thanks.
Apr 24, 2012 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
I need a manual for Tripp lite omniplus 1000 lcd
Changing the battery
If your Tripp LIte Omni 1000 LCD display a fault icon and beeps after changing the battery, try the advice given by the buzzerman which worked perfect in this case:
1. Turn the UPS on. Press and hold the ON/OFF button for one second.
2. Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until beeps several times). The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound. At the end of this process the fault icon and the beeping turned off.
Feb 15, 2012 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
The LCD display no longer works on my Tripp Lite Omni 1000 LCD. Also, half of the power outlets on the back of the unit no longer work.
Be aware.
My Tripp LIte Omni 1000 LCD almost caught on fire.
I had been experiencing a spike in my power bill to the tune of 1000 Watts an hour for everything running - 24x7. I started the survey of all my equipment; TV 162 Watts; Fridge 228, etc. but none of these devices are on all day and night. I finally mapped out all the outlets and lights and was about to begin the survey. Other than the flickering lights, one big clue was that my TL's lcd was displaying a spike in voltage DOWN to 95 or so, the relay would click, etc.
I decided to begin my survey and use my second TL to help me see which circuit was faulty. When I looked at the LCD, it was blank. I pushed the ON button and all the devices plugged in went OFF and then I saw smoke coming out of the back. I quickly unplugged everything and then watched my meter. When this UPS was plugged in, there was about 1000W used per hour; I monitored it for 10 hours; 400W were used (total).
So... not only was it a fire hazard, but it sucked up 900W or so an hour.
Nov 28, 2010 | Tripp Lite (OMNI1000LCD) UPS System
Hello! I'm from Riyadh Saudi Arabia. I've left on my Tripp Lite UPS 1000 just last night. When I came in my office in the morning, my desktop computer including my computer server was OFF. I supprised that...
Unplug the computer. Then run the UPS self-test and the unit will display whether it finds an overload fault, whether the battery needs to be charged or replaced.
Here are the instructions (copied from the User Manual):
Jul 01, 2010 | Tripp Lite (OMNIVSINT1000) UPS System
Feb 19, 2010 | Tripp Lite OMNIVS1000 UPS System
Tripp Lite Smart Pro UPS System Logo
811 people viewed this question
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
