Question about Saws
I own a skilsaw 4470 and can't figure out how to replace the blade. Help please?
  • tags1162 May 11, 2010
    is this a 7and a quarter inch blade with a bolt in the middle , there should be a blade catch that u push in this holds it from spinning then loosen that bolt and ur blade should come off , righty tighty, lefty loosey
  • 2,176 Answers
Apparently this is an older tool and I can't find an owners manual online for you but you can call them direct at 1-877-754-5999 and request a PDF be sent to you. It appears as though there a 2 screws on the one side of the blade holder that need to be loosened and the blade inserted and tightened, Make sure to unplug the tool prior to installing or removing the blade. If I have helped you with your request would you please rate this response accordingly. Thank you.
Posted on Oct 10, 2009
Have a Skilsaw 3315 that works fine. Except the blade continues to spin after shut off. It’s not a loose blade. I’m not sure what else to fix. Seems like a brake doesn’t engage or something. Please help.
kninejk Feb 11, 2018
Based on your model number given this saw does not have a blade brake so the blade will spin after turning the saw off, it must coast to a stop.
Feb 11, 2018 | Garden
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
Skilsaw 5380 blade installation problem.
Don't know exactly, but on amazon you can find user manual. here Skil Circular Saw Model 5350 Owner Manual Operating Guide Paperback 1988 . Hope this was helpful. cheers skilsaw-5380-blade-installation-problem-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 20, 2013 | Skilsaw 5380 Circular Saws
How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Jun 07, 2010 | Skil Saws
Can't figure out the skilsaw 3315
PLEASE PLEASE Do Not Use this saw!! The lock is on the right side. Little black button. Press the saw down a bit an pop the button out. May have nightmares after answering! LOL
Mar 26, 2010 | Skil 10" Table Saw
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
How to replace a guard spring on a model 367 skilsaw
take blade off and under blade there is a giude around shaft area around housing where sping goes i hope this was helpful
Aug 28, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Where is blade lock for my Skilsaw 5150 located
look for the button on the right side of the handle. Other models require you to put a phillips head screwdriver into a hole in the blade to hold it against the body of the saw.
Jul 13, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Skilsaw motor runs blade won't turn
It sounds like you bought a lemon possibly. I am thinking that the gears are bad. What you can do is remove the blade and unplug the saw. locate where the screws holding the bearing cover are and remove them to get to the gear and check it. Let me know if you need more help
Jun 27, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Saws Logo
393 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
