Question about Braun FlavorSelect KF 180 Coffee Maker
Great Machine, I have had it for years. Last week the machine was programmed to brew the coffee at 5:00am but when I went downstairs to get a cup, the red light was on that it was brewed but no water went through the system to the grounded coffee beans. I have tried several times but the water stays in the reservior and does not circulate to get hot and flow through the coffee beans. Gary
  • gpepp Sep 28, 2009
    Solution was helpful, I dumped the machine in the trash
  • 615 Answers
That sound as the thermostat out that heat the water and let it drop on the coffee you need to check on that if you like to open it and see but before you start your journey see first of any parts are available and the cost of it. ...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 26, 2009
Coffe maker has shut off no power
Pad and Circuit board shorted. Return for replacement.
Jan 22, 2012 | Keurig Platinum B70 Coffee Maker
The machine pours too much coffee for an expresso and even for a normal cup. We have been using it for 3 years and this just started a few weeks ago. I reset the machine to factory settings and it still...
You don't mention if you've programmed the quantity since it started behaving strangely, so....
instead of pressing the 'coffee cup ' icon button once, hold it down all the way through the brewing procedure (it will bip) until the correct amount of coffee has been pumped into your cup, then release the button. This quantity has now been programmed into the memory and should produce the same amount of coffee every time, on a sigle press.
Mar 04, 2011 | Saeco Incanto Sirius Fully Automatic...
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup...
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Aug 15, 2009 | Keurig B60 Coffee Maker
Brewer pushing water back into reservoir, not brewing... any suggestions? De-scaled last week (used all week with no problem). Cleaned needle today, no change.
I had the same problem, contacted Keurig and they suggested the descale procedure, which did not work. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, let sit 2 hours and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since.
Jul 12, 2009 | Keurig B70 Coffee Maker
Since I cleaned our Cuisinart 12-cup Brew Central with "Dip-it"  destainer last week, it takes about 3 times longer to brew, and it steams outrageously practically the whole time.  Using the same...
Run 1/3 caraffe vinegar and 2/3 caraffe water through the machine.
Dip-It is not the best cleaner to use with this coffeemaker - stick to distilled white vinegar.
If the cleaning fails to resolve the issue, and the unit was purchased in the last 3 years, call Cuisinart and see if you are still in-warranty.
Mar 14, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Feb 14, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Coffee crounds
The problem you are having is common when these units have been in use for a while. There is a sludge buildup preventing the brewed coffee from leaving the brewer soon enough. Straighten out a paper clip and use the wire to open up the blockage in the hole where the coffee would enter the coffee cup. You may have to go up from the bottom in order to do this thoroughly.
Feb 12, 2009 | Lavazza Espresso Point Capsule Machine
Saeco Vienna: water does not go through to the main unit
on the brew unit the plastic screw that hold the filter mush be loose or broken check that out pierre
May 20, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Jan 11, 2008 | Saeco Royal Professional Espresso Machine
Wont brew a full pot
I had the exact same problem with my machine making 1 cup at a time.
Here is the solution:
1. make solution of 1 part vinegar & 2 parts water.
2. pour solution into resivoir and set for 2 hours
3. run solution through machine (yes, you will have to stand there and keep pushing the buttons).
4. take same solution (now very hot) and run it through machine 5 or 6 times
5. make fresh solution and continue process until machine runs full cycle.
May 27, 2007 | Cuisinart DGB-600 Coffee Maker
Braun FlavorSelect KF 180 Coffee Maker Logo
65 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
