Question about Panasonic PT-47WX49 47" Rear Projection Television
Diagonal lines My projection T.V. just started have a picture that is made up of all diagonal line (from top left to bottom right). The audio is unchanged. Any suggestions???
  • fixyawannabe Dec 17, 2007
    Thank you for your quick response. I hope to be able to apply your solution in the next few days, and will let you know the outcome.
  • fixyawannabe Dec 24, 2007
    CTF1800,
    Thank you for the DOUBLE SET suggestion. I tried it a couple of different ways, but unfortunately it didn't make a difference.
    President:
  • 4,402 Answers
You should try a double reset; this may reset the memory (actually eeproms) in the convergence board. If it does not work, then you will have to keep adjusting or replace the bad components on the board - which you may have trouble finding someone with enough smarts to know how to diagnose let alone do the delicate repairs.
DOUBLE RESET: Unplug the power cord for 4 hours. Power on the set for 10 minutes; make no adjustments. Then unplug again for at least 4 hours.
Let me know the outcome
Posted on Dec 17, 2007
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
I have diagonal lines on the picture of Samsung HLM50
Most likely bulb is not in correctly or a issue with the optical light engine this set uses
Nov 29, 2012 | Samsung HLM507W 50" Rear Projection HDTV
Basically i have an older rear projection model mitsubishi not sure of the model #, it is currently having lines run from top to bottom like waves on the picture screen! is there anything you can tell me...
Many different mitsubishi's have problems with voltage regulators going out and causing wavy diagonal lines that scroll the picture from top to bottom or vice versa. Without a model number it's difficult to clarify.
Jul 05, 2010 | Mitsubishi VS-55609 55" Rear Projection...
Puzzle 100
heres a hint
1. Most of the squares you make will be tilted 45 degrees
to the side, and their sizes will vary as well.
Start by looking for pins you can connect to create squares
at a diagonal.
2. You want more specifics? All right, here's the location
of one of the squares. Connect the four pins in the top-left
corner to form a tiny square. Just so you know, this is the
only square on the board that isn't tilted.
3. The largest square contains the pin that's third from
the top on the left column and the bottom pin from the far-right
column. You also need to form a small diagonal block using the
two pins lined up diagonally on the bottom-left portion of the
board. There are two more small squares just like this one on the board.
J5
Jan 13, 2009 | Nintendo Professor Layton & the Curious...
Diagonal lines through the picture of Samsung DLP set.
Hi
where the line is coming out? from left to right of your screen or bottom to top?
Thanks!
Dec 27, 2008 | Televison & Video
Diagonal lines on a Samsung 46" TV
picture is ok /converg.-ok/;diagonal lines on screen; looks like waves.Appear on tv and video modes.I observed same problem on some another tv in my practic,but this case is worse.
Sep 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
Diagonal lines moving from bottom to top
sample of a line diagnally from bottom to top of page.
Dec 20, 2007 | Gateway LCD30TV Television
Red diagonal spottted lines
These are called retrace lines they occur because of the blanking pulse not turning off the electron guns in the picture tube during the retrace period. Since this is occuring with the red gun there may be a proble with the video circuitry connected to the red electron gun of the picture tube. This would include the red amp and the red driver transistors. You will need a schematic and a multimeter to properly test these items.
Aug 03, 2006 | Sony KV-36XBR400 36" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
