Question about Minolta EP4000/5000 CS/PRO Copier
Trouble code COb60
According to the trouble shooting manual. It says this is abin motion failure.
Refer to service manual ST210/S-207. What is the fix for this?
  • kwhitt Feb 15, 2008
    I have the EP400 with a COB63 error code any ideas?
    Problem Solver:
  • 12 Answers
HOME SENSOR MAYBE DIRTY OR HAS GONE BAD
Posted on Dec 31, 2007
Just installed a Rheem RTG-95DVLN. Tried turning it on but all im getting is the # 82 flashing & beeping incessantly! Anybody know why or have any suggestions? Im completely stumped...
According to Rheem trouble shooting, at the end of page 61, error code 82:
Error Code 82
Explanation: Gas Type Control Data Failure; Printed Circuit Board data failure. The PCB has not
been programmed, lost its programming or has failed.
5. If the unit does not operate on initial installation or after replacement of the PCB, then the
circuit board requires programming with the fuel type and altitude chip.
http://hometips.me/Tls/SVC810-Rheem-Ruud-Tankless-Service-manual-2008.pdf
Feb 17, 2016 | Rheem Water Heaters
Normal cycle will not start and keeps beeping
Count the pattern of beeps and refer to the trouble shooting section of your owners manual. Beeps are trouble codes on digital appliance control panels. If that doesn't work kill the power for 2 minutes and try again. After that go to repairclinic.com. enter your model number in the trouble shooting section and follow directions.
Aug 12, 2015 | Dishwashers
Hi i just bought Electrolux Dishwasher ESF2433W When i first time turn it on, the "Normal" button light keep on flashing with beeping sound. According to the trouble shooting manual, it actually refer to...
If you just bought Dishwasher ESF2433W I suggest you contact an authorized service center because the appliance is under warranty..
E4 : if overflow micro-switch is act and keep for longer than 2 seconds, the E4 would occur. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown.
Sometimes defects are generated by incorrect transportation appliances so that should be taken into consideration.
Dado
Feb 20, 2015 | Electrolux Dishwashers
My computerized Brother sewing machine won't come on.
this what i have found,,try this link. Fixing common sewing machine problems Service Support Brother Sewing and... ..
when you go to this page you will see this.. Fixing common sewing machine problems
Sewing machine manual.
Should you encounter a problem with your sewing machine, it's best to refer to the instruction manual supplied with your machine. This will contain details of the correct settings for your machine and may contain a trouble shooting guide.
If you don't have this most Brother sewing machine manuals can be found here ..
where it is saying,(can be found here) just click that.on the next page you just pick your model and you should be able to trouble shoot your problem from the manual..
or you could also go to this link and see if it helps you out.
My computerized Brother sewing machine won come on Google Search
Oct 27, 2017 | Sewing Machines
C-0960 error
C0960 Bypass lifting motion failure. To fix this problem, check that there is a clear paper path. The take-up roller has possible not returned to the 'home' position. Turn off the copier, manually rotate the roller to check that it is free. Turn on the copier, once start-up is completed, check that the paper path sensors are clean. Close the by-pass tray and open again. If this fails to reset the code, refer to your service technician.
Aug 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
After a power outage,the tv wont turn all the way on,the blue light keeps blinking.why?
hello, if you have a blinking light this means theres a voltage drop or failure causing a circut fault some where inside, you need to find a service manual for your set or have it checked out by a tech. there are high voltages and live circuts inside so if your attempting a fix on your own be aware of this and get a service manual it will tell you according to the blinks whats the trouble or what part to replace or service. hope this helps.
Oct 14, 2009 | Televison & Video
Wii keeps giving error message An error has occurred. Press the eject button and remove disc then turn the wii console off and refer to the wii operations manual for help trouble shooting. the message...
Have you tried unplugging the unit for about an hour then testing it again but in a different position? If that doesnot work it is most likely a laser failure and you will need to get it serviced.
I hope this helps. Good luck to you.
Aug 04, 2008 | Nintendo Video Game Consoles & Games
Boot failure
Dead Hard Drive. Thats all i can tell you. Did you hit a huge pothole or drop it today? With the way firmware is today you'll juest need to send him in. Sorry to say it, but that's the solution! thanks! Let me know of any followup needed
Jun 23, 2007 | iRiver PMP-120 Digital Media Player
Iriver PMP-140 boot failure message
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
System file has an error.
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
May 13, 2007 | iRiver PMP-140 Digital Media Player
118 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
